Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 27th Apr 2017, 14:35   #1
raidensub
What's a Dremel?
raidensub has yet to learn the way of the Dremel
Help for modding Aerocool VS-3
My case is the Aerocool VS-3 and i got bored with the looks of the case. I haven't done any modding in the past and i am thinking to remove the front plastic panel and make a new flat panel with a grill and 2 120mm fans. Can someone tell me how should i make this panel or point me in the right direction for information? I don't have a lot of money, please keep the recommendations in the cheap side. Thanks.
raidensub is offline   Reply With Quote
Old 30th Apr 2017, 10:42   #2
Impatience
Ultramodder
Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.
Do you currently own a Dremel/rotary cutter or drill or a jigsaw? If the answer to that is a no, it may be a cheaper option to buy a new case with a flat panel design. It's a lot easier to mod a blank front panel than it is to mod a moulded plastic one.
If you were wanting to completely make a new front panel from scratch, I'd suggest to first see if the fans/optical drive bays/io recess into the moulded front panel. As if they do, you'd have to factor that into the design process.
If they don't could just get a sheet of acrylic and draw your design onto the protective film, then cut out the design with a plastic cutting blade or Dremel and glue it onto the front of the interior shell.
Impatience is offline   Reply With Quote
Old 30th Apr 2017, 18:35   #3
raidensub
What's a Dremel?
Thank you for your help. I don't have a rotary tool but i was thinking to buy one. I will probably buy a new case with a better design and if i buy a rotary tool i will experiment with the old one. I like the modded cases i see online and i want to try to make one.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
