Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 28th Apr 2017, 17:03   #1
GravitySmacked
Mostly Harmless
GravitySmacked's Avatar
GravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming Saiyan
Budget Build Advice Please
Hi folks,
I'm building a budget gaming system for my daughter soon and I'm in the process of speccing it out.
I would appreciate any advice as to whether there are better / more cost effective components at the budget end as I'm not really up to speed. It needs to be a foundation that she can build on but I know that will be somewhat limited by cost.
Ideally, I'd like to try and get the total price down to 400 ish.
I've already got some of the components from old builds but this is what I have so far.
CPU - Intel Pentium G4560 @ 58.98
RAM - 8GB (2x4GB) Corsair DDR4 Vengeance LPX Black @ 69.98
Mobo - Asus PRIME Z270-P @ 113.38
GPU - EVGA GeForce GTX 1050 Ti SC GAMING 4GB GDDR5 @ 144.98
Hard Drive - 120GB WD Green SSD @51.49
Case - Aerocool Aero -500 White Windowed @ 39.98
PSU - Already got (850W BeQuiet) @ 0.00
OS - Already got (Win 10) @ 0.00
Mouse - Already got (G402) @ 0.00
Keyboard - Already got (Cyborg) @ 0.00
Monitor - Already got (Dell) @ 0.00
TOTAL = 478.79
Cheers
GravitySmacked is offline   Reply With Quote
Old 28th Apr 2017, 17:21   #2
Omnislip
Modder
Omnislip has yet to learn the way of the Dremel
I don't think you need such a sophisticated motherboard for a CPU that is not overclockable nor particularly demanding. Dropping down the sockets will save some serious cash.
The PSU is also overkill - I don't know if you could sell it and get a lower-power one to save money, but it would also save in the long run as the lower power PSU would run in its highest efficiency range.
You might be able to pick up a leftover RX480 for not much more than the 1050 too.
Omnislip is offline   Reply With Quote
Old 28th Apr 2017, 17:24   #3
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
Did you think about going down the second hand route? You'd get significantly more bang for your buck.
__________________
ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480@RX580 8GB with VRAM strap mod | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv TG | CM Masterkeys Pro L | Logitech G502 | Logitech G920 | ASUS ZenBook UX305F
TheMadDutchDude is online now   Reply With Quote
Old 28th Apr 2017, 17:47   #4
modd1uk
Mod Master
modd1uk's Avatar
modd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyan
As omnislip said, the motherboard isn't needed with that pentium, save some dorrah and go B250.
__________________
Originally Posted by Nexxo View Post
Report him for being a dick. Which should be a criminal offense IMO.
Originally Posted by Gareth Halfacree View Post
There you are, then! Buy 100, take two, eBay a bundle of 98 at 70% the price of the 100-bag bundles, spend the profit on ale and whores.
modd1uk is offline   Reply With Quote
Old 28th Apr 2017, 17:47   #5
GravitySmacked
Mostly Harmless
Thanks for the replies and advice.
@Omnislip / @modd1uk The PSU is pretty old and not worth much now but yeah, I do realise it's total overkill for this build but it's just sat around not being used.
The reasoning behind the mobo was to enable a future CPU upgrade with the possibility of overclocking but it does add a lot to the cost so I'll keep looking for something cheaper.
@TheMadDutchDude I'd prefer to go the new route as I've been burnt buying second hand components before but I am keeping my eyes on the sellers forum
Old 28th Apr 2017, 17:49   #6
Omnislip
Modder
The chipset won't be alive for much longer so if you don't want to go second hand then it might be tricky to source that CPU upgrade in the future!
You could downgrade to a Z170 motherboard still and save some money, unless you need copious numbers of drives.
Old 28th Apr 2017, 18:09   #7
GravitySmacked
Mostly Harmless
Aye but there are plenty of options on that chipset with the dreaded second hand but you're right, the mobo is overkill.
I'll have a look at Z170 and B250 and see what's around
Thanks everyone.
Old 28th Apr 2017, 18:20   #8
Anfield
Mod Master
Anfield's Avatar
Anfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming Saiyan
Z170 and its cut down variants are a gamble, some of them require a bios update to work with Kaby Lake CPUs and you would then first need to get your hands on an old CPU just for the bios update.
No such risks with Z270 and its cut down variants though.
The Asus Prime B250M-K is somewhere in the 60 - 70 range for example.
__________________
R7 1800X, ASRock X370 Taichi, 2x8GB Corsair Vengeance 3000 DDR4, ASUS Strix 1080TI OC, 512GB Samsung 950 Pro, 4TB WD Black, EVGA T2 1KW, Lian Li PC-O9WX, EK Supremacy Evo, EK-XRES 140 DDC 3.2, EK-CoolStream PE 360, Ducky Shine 6 (Brown Switches), Logitech G402, AOC U3477PQU (34" 21:9 ftw)
Anfield is offline   Reply With Quote
Old 29th Apr 2017, 00:17   #9
MSHunter
Mod Master
MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.
I just got a used HP elite desk for my wife's work pc with a I7 8gb ram and 128 GH SSD for 300 pounds on ebay. Add in the Lowprofile 1050ti and it is at the same price as your build. Just food for thought.
__________________
Caved and bought a Gigabyte P35x V3 gaming laptop.
ex-PC: Silverstone TJ08B-E, 2500K, Corsair H80, 256 GB Samsung 830,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711
PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X
Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1
MSHunter is offline   Reply With Quote
Old 5th May 2017, 23:13   #10
GravitySmacked
Mostly Harmless
Thanks for the advice everyone, much appreciated
I've taken it all onboard and pretty much settled for the following:
RAM - 8GB (1x8GB) Corsair DDR4 Vengeance LPX Black, PC4-19200 (2400) @ 63.98
Motherboard - Asus PRIME B250M-K @ 61.99
GPU - Asus NVIDIA GeForce GTX 1060 TURBO White @ 178.99
Hard Drive - 120GB WD Green SSD @ 51.49
WiFi - - Asus PCE-N15 PCIe 300Mbps 802.11b/g/n Wireless Adaptor @ 13.99
Case - Corsair CC-9011086-WW Carbide Series 88R 51.98
TOTAL @ 497.24
Slightly over budget but I think it's a good balance for a cheap little gaming system
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
