Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 30th Apr 2017, 20:02   #1
numanoid
Mod Master
numanoid's Avatar
numanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for president
Will my H80i fit
Hi guys ive just bought a GIGABYTE Z170X-Gaming 7 motherboard and 7700k cpu, thing is. Will the h80i i used on my old 4790 motherboard fit my new setup, thanks guys
numanoid is online now   Reply With Quote
Old 30th Apr 2017, 20:16   #2
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
It should.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 30th Apr 2017, 20:23   #3
numanoid
Mod Master
numanoid's Avatar
Cheers matey
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
