Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 2nd May 2017, 13:58   #1
Pie_uk
British beef, in Britain
Pie_uk's Avatar
Pie_uk is definitely a rep cheat.Pie_uk is definitely a rep cheat.Pie_uk is definitely a rep cheat.Pie_uk is definitely a rep cheat.Pie_uk is definitely a rep cheat.Pie_uk is definitely a rep cheat.Pie_uk is definitely a rep cheat.Pie_uk is definitely a rep cheat.Pie_uk is definitely a rep cheat.Pie_uk is definitely a rep cheat.Pie_uk is definitely a rep cheat.
Back once again, power to the people..
Hello people!
It has been an age since I have posted here, or even looked at a windows pc.. so hello everyone
To keep it short, I am looking at a PC to be able to make music using fruity loop studio. I currently have a Mac book pro, and to my knowledge you cant get FL studio natively on mac systems. Before I go and ask for help to spec a system to perform the aforementioned task, does anyone have any advice regarding this software working on Mac? am I best going to the dark side..
Muchas gracias
__________________
MacBook Air
Pie_uk is offline   Reply With Quote
Old 2nd May 2017, 14:05   #2
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Boot camp and Windees ?
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 2nd May 2017, 14:20   #3
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
Fairly sure you can get FL Studio working on macOS using WINE.
Failing that it's bootcamp... or using something that's not FL studio.
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is online now   Reply With Quote
Old 2nd May 2017, 14:31   #4
Vault-Tec
Vault-Tec's Avatar
I'm going to play with BC and Win 7 in a few days. Will report back when I've done it
__________________
MUWC Winner ROTT
Old 2nd May 2017, 15:40   #5
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
FL Studio Native MacOS Alpha 0.9P
Just a few minor things missing or not working properly yet, but allmost there.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
