Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 3rd May 2017, 17:33   #1
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
reaffirm my choice of SSD
I'll cut to the chase - is the Samsung 960 evo still the go-to option for SSDs?
My requirements are:
£120 or less
250GB or larger
m.2 if possible
Available from Amazon [as it'll be bought with vouchers].
The 960 ticks all the right boxes, but just getting second opinions before pulling the trigger.
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is offline   Reply With Quote
Old 3rd May 2017, 18:04   #2
Anfield
Mod Master
Anfield's Avatar
Anfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming Saiyan
There are actually two competitors available at the capacity relevant for the budget.
The Corsair MP500 and the PNY CS2030.
Which one is the fastest? They trade blows from one bench to the next with no clear winner, so ultimately it just comes down to which one is the cheapest of the three and which brand you trust your data with.
__________________
R7 1800X, ASRock X370 Taichi, 2x8GB Corsair Vengeance 3000 DDR4, ASUS Strix 1080TI OC, 512GB Samsung 950 Pro, 4TB WD Black, EVGA T2 1KW, Lian Li PC-O9WX, EK Supremacy Evo, EK-XRES 140 DDC 3.2, EK-CoolStream PE 360, Ducky Shine 6 (Brown Switches), Logitech G402, AOC U3477PQU (34" 21:9 ftw)
Anfield is offline   Reply With Quote
Old 3rd May 2017, 18:06   #3
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
I'd buy the Samsung 960 EVO if it were me.
Just to check - what board is it you're intending to use it with?
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is offline   Reply With Quote
Old 3rd May 2017, 18:11   #4
RedFlames
RedFlames's Avatar
ASUS Z97 Pro, so it supports NVMe
Sure I could cheap out and get a sata model but that means finding cables and screws to mount it in the case and... well... **** that noise...
And i did look at the PNY and a Plextor, but the Samsung was the cheapest by a fair margin.
__________________
Old 3rd May 2017, 18:16   #5
bawjaws
Mod Master
bawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyan
Does it have to be an NVMe m.2 or would a SATA m.2 do instead?
bawjaws is online now   Reply With Quote
Old 3rd May 2017, 18:19   #6
Anfield
Mod Master
Anfield's Avatar
The Plextor M8P has the same problem as the WD Black and the Intel 600P, slow write speeds, all three of them are only worth it if you get them at a very good price.
Only the PNY and Corsair ones can compete for performance, but price matters and if the Samsung is the cheapest there is no reason to opt for either PNY or Corsair.
__________________
Old 3rd May 2017, 18:19   #7
RedFlames
RedFlames's Avatar
I'd rather it be an nvme SSD, though if i could get a 500GB sata model for my budget i might consider it.
__________________
Old 3rd May 2017, 18:25   #8
Anfield
Mod Master
Anfield's Avatar
Prob the best deal around on the cheap M.2 Sata ones:
https://www.amazon.co.uk/Crucial-MX3.../dp/B01L80DH4G
525GB from a reputable brand for £137.
__________________
Old 3rd May 2017, 18:42   #9
RedFlames
RedFlames's Avatar
Sadly £120 is a hard limit that I can't go beyond.
Were it not for the vouchers I'd have to make do with my current arrangement of running from a Linux live usb image and hoping i can still retrieve stuff off my knackered HDD should i need to.
and £120 doesn't even come close to fixing the other things wrong with my pc so a SSD is probably the most efficient use of it.
__________________
Old 3rd May 2017, 18:52   #10
jinq-sea
Moderator
jinq-sea's Avatar
I couldn't get my Z97 board to recognise a SATA M.2, so I'd stick with NVMe.
__________________
Old 3rd May 2017, 19:23   #11
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Sure you can't stretch your budget just a little
GeorgeK is offline   Reply With Quote
Old 3rd May 2017, 19:42   #12
RedFlames
RedFlames's Avatar
Nope, I have £120 of amazon vouchers and that's it. If it's more than £120 or not on amazon, it's not happening.
EDIT: and the humour has gone right over my head... derp...
Sure, i'd love a 2TB SSD, i'd love a lot of things... but right now my pc is held together with wishful thinking and compromises... as i said, were it not for these vouchers falling in my lap, i'd be running of this live usb for the forseeable.
__________________
Old 3rd May 2017, 20:45   #13
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
Haha no worries. On a more on-topic note, in your position I would 100% go for the 960 from Amazon if you can get it in budget
Old 3rd May 2017, 22:42   #14
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
That's the Stretch Armstrong of stretches
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 4th May 2017, 08:47   #15
The_Crapman
Don't phone it's just for fun.
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Seems firm to me. I found the Corsair and pny to be a little squishy.
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 4th May 2017, 12:13   #16
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
Haha - certainly is I'm amazed that there are 2TB NVMe drives commercially available (i.e. readily stocked by suppliers) - who has the money to buy them?! Well other than Jinq I suppose
Old 5th May 2017, 20:36   #17
RedFlames
RedFlames's Avatar
Well it looks like the SSD isn't happening, but +rep to those who responded.
__________________
Old 6th May 2017, 07:42   #18
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
Shame
Old 6th May 2017, 11:14   #19
sandys
Mod Master
sandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpit
£120 quid nvme on Amazon, I have this it is plenty quick.
https://www.amazon.co.uk/Samsung-M-2...=samsung+pm961
sandys is offline   Reply With Quote
Old 10th May 2017, 08:37   #20
crazyland
What's a Dremel?
crazyland has yet to learn the way of the Dremel
Also like Samsung
crazyland is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
