Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 5th May 2017, 17:02   #1
d_stilgar
Old School Modder
d_stilgar's Avatar
d_stilgar is definitely a rep cheat.d_stilgar is definitely a rep cheat.d_stilgar is definitely a rep cheat.d_stilgar is definitely a rep cheat.d_stilgar is definitely a rep cheat.d_stilgar is definitely a rep cheat.d_stilgar is definitely a rep cheat.d_stilgar is definitely a rep cheat.d_stilgar is definitely a rep cheat.d_stilgar is definitely a rep cheat.d_stilgar is definitely a rep cheat.
Help my find/choose a GPU
I have a 3u computer case that I use for my HTPC. I'd like to use it for gaming a little more. It currently has an R7 260x, which is fine for plenty of games, but can't do VR, which is what I'd like this computer to be capable of.
The issue is that I have very tight height restrictions on the GPU. My current GPU has its power connector coming out the rear of the card. I need any GPU I buy to also have its power out the back or else my case won't close.
Does anyone know of any GPUs that would fit my requirements? None of the normal GPU selection tools let you pick where the power connector is. Thanks in advance.
d_stilgar is offline   Reply With Quote
Old 5th May 2017, 17:29   #2
atc95
I have the upgrade bug!
atc95's Avatar
atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.
Is there room for a standard side power connector if you use a low profile cable? Will open you up to a lot more choice, can't link as I'm on my phone but I believe ModDiy sell a low profile pci-e cable.
__________________
PC: It's a work in progress, but isn't it always...
Check us out on twitch at https://www.twitch.tv/digitalbacongaming
atc95 is online now   Reply With Quote
Old 5th May 2017, 21:19   #3
d_stilgar
Old School Modder
d_stilgar's Avatar
Effectively, no. The top of a reference GPU PCB is more or less touching the top panel that closes the case. I'm realizing this is a pretty big limitation moving forward. I'll either have to solder my own headers onto any GPU I buy (which lets me get most cards), buy low-profile cards (which are all really crappy and almost never require extra power anyway), or try and hunt down any weird versions of cards where the power is coming from the back of the card.
1st world problems.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
