Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 6th May 2017, 12:02   #1
Nealieboyee
Packaging Master!
Nealieboyee's Avatar
Nealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming Saiyan
Pcie riser question
I'm planning a build where I need the GPU to be parallel to the motherboard. If I use a flexible riser that's only rated at 25w but my graphics card has its own 6pin power connector, will I be ok to run any GPU?
__________________
CLARISSE
G4560 | Gigabyte GA-H110M-S2H | 8GB Kingston HyperX | GTX550ti | Sandisk Plus 120GB | Corsair CX430 | Cooler Master Hyper 212 PLUS
Nealieboyee is offline   Reply With Quote
Old 6th May 2017, 13:05   #2
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
IIRC 25w is intended for low power PCIe so no you won't be ok.
Corky42 is offline   Reply With Quote
Old 6th May 2017, 13:35   #3
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
I could be wrong but I thought that graphics cards with PCIe connectors draw power from both the motherboard and the 6 / 8 pin connector/s so you probably won't get away with it no
GeorgeK is online now   Reply With Quote
Old 6th May 2017, 14:34   #4
Nealieboyee
Packaging Master!
Oh ok. So how do I use a riser with enough power for the GPU without burning the riser cable?
__________________
CLARISSE
Old 6th May 2017, 15:08   #5
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
You need to get either 1) a premium one capable of carrying at least 75w or 2) one with an in line power adapter. You'll burn the cable otherwise.
__________________
ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480@RX580 8GB with VRAM strap mod | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv TG | CM Masterkeys Pro L | Logitech G502 | Logitech G920 | ASUS ZenBook UX305F
TheMadDutchDude is online now   Reply With Quote
Old 7th May 2017, 11:58   #6
edzieba
Virtual Realist
edzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyan
For flexible risers, there are a few choices:
3M Riser. Expensive, but will work, always.
LiHeat riser: cheaper than 3M, but less flexible. A bit of a pain to get one, but has variants with different angled connectors, and the newer ones have a narrower flex ribbon. A handful of stores of DOA risers, but few of failures in use.
HDPlex riser: Cheap, works well, flexible substrate, connectors are a bit bulky, only available in one length. Currently unavailable new.
Other risers: Barely worth bothering with. You might get something that works, you might get a lemon. Enjoy wasting your time with trail & error.
edzieba is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
