Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 7th May 2017, 09:39   #1
Concrete-Coffin
Supermodder
Concrete-Coffin's Avatar
Concrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming Saiyan
2500k upgrade to 4770k
just need a bit of advice to see if its worth it. I can get a 4770k and a msi z87-gd65 gaming mobo and a 128gb msata card for 140 as my 2500k still going ok in games etc
__________________
I5 2500K @ 4.2ghz l GA P67A UD4 B3- F7a BIOSl 8GB corsair 1600mhz l rx 480 8gbl CM 690 II advance l corsair H60 l F3 1TB Spinner l crucial M4 128 SSD l 650w evga GQ l
Concrete-Coffin is offline   Reply With Quote
Old 7th May 2017, 10:10   #2
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
For that price, yes, go for it.
The performance increase won't be huge but upgrading two generations for that price is worthwhile, plus you'll claw back at least half of it by selling your 2500K and mobo.
Cheap upgrade.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|980 Ti|3007WFP-HC|Parvum S2.0
David is offline   Reply With Quote
Old 7th May 2017, 10:34   #3
Concrete-Coffin
Supermodder
Cheers David think all go for it then
__________________
Old 7th May 2017, 10:36   #4
atc95
I have the upgrade bug!
atc95's Avatar
atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.
Originally Posted by Concrete-Coffin View Post
just need a bit of advice to see if its worth it. I can get a 4770k and a msi z87-gd65 gaming mobo for 140 as my 2500k still going ok in games etc
A great price but upgrading to a platform that still doesn't have M.2 or DDR4 is a bit pointless imo.
__________________
PC: It's a work in progress, but isn't it always...
Check us out on twitch at https://www.twitch.tv/digitalbacongaming
atc95 is offline   Reply With Quote
Old 7th May 2017, 11:06   #5
Concrete-Coffin
Supermodder
i would of liked to go newer but funds at the moment for a full overhaul are limited and this would last a little longer
__________________
Old 7th May 2017, 11:54   #6
David
RIP Tel
David's Avatar
M.2 isn't all that big a deal - I've been running an NVMe SSD as my OS drive for over a year, and it's not noticeably faster than a decent quality SATA3 SSD; despite boasting 4x the read speed and over twice the write speed of any of my SSDs.
Also DDR4 is fooking expensive right now, and the prices are set to either increase or plateau for the rest of the year - this upgrade won't require new RAM. From a value for money point of view, this is a no brainer.
A Kaby upgrade will set the OP back 500, without m.2.
__________________
Old 7th May 2017, 13:51   #7
silk186
Canadian
silk186's Avatar
silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.
not going DDR4 means he can reuse his DDR3, that reduces cost now. When he finally does move to DDR4 prices should have improved.
__________________
i5 2500k @ 4.4GHz :: hyper 212+ :: GA-Z68-UD3H-B3 :: MSI 280x 3GB :: Corsair Vengance 2x4GB:: Samsung 830 256GB :: 2x Toshiba 3TB :: Corsair RM650 :: CM Storm Enforcer :: ASUS VE247H :: LG 42LB5500 :: Microlabs Fc360
silk186 is offline   Reply With Quote
Old 7th May 2017, 15:53   #8
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
Bargain. You should jump on it! The CPU is worth the 140 on its own.
NVMe can be used on Z87 with a bit of tweaking. It's not too difficult. I definitely notice the difference between my 850s and the SM951 when it comes to loading things. It doesn't have as big a difference between going from a HDD to an SSD, but the difference is still there.
__________________
ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480@RX580 8GB with VRAM strap mod | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv TG | CM Masterkeys Pro L | Logitech G502 | Logitech G920 | ASUS ZenBook UX305F
TheMadDutchDude is online now   Reply With Quote
Old 7th May 2017, 16:06   #9
Concrete-Coffin
Supermodder
just bought it from a m8 at work so hopefully have it up and running when get a chance to pull me pc apart thanks for the input lads
__________________
Old 7th May 2017, 16:11   #10
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Yeah that's a great price. I saw loads of people go through Sandy/Ivy/Haswell etc. Very worthy upgrade IMO. Extra threads are always nice too
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 7th May 2017, 17:40   #11
Yadda
Vegan Sandwich
Yadda's Avatar
Yadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming Saiyan
Will definitely keep you going for longer than your 2500k and a great price too.
Bargain!
__________________
Lost a Duff, gained a Charlie.
i5 4690k @ 4.6GHz / ASRock Z97m OC Formula mATX / 2x8GB Crucial Tactical DDR3 @ 2200MHz C10 / EVGA GTX 780 @ 1200/6400MHz / BX100 250GB SSD / Seagate 2TB SSHD / Nepton 240m AIO / EVGA 600B PSU / Corsair Carbide Air 240 / Win10 Home / 1080p monitor / Logitech MOMO wheel
Yadda is offline   Reply With Quote
Old 8th May 2017, 12:45   #12
Wakka
Yo, eat this, ya?
Wakka's Avatar
Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.
I can't figure out if it's a testament to how good the 2500K was, or how bad Intel have been at actually moving the performance post forward haha.
My 2500K was the first CPU I've ever owned for more than 3 years (was actually close to 4), was a sad day to see her go...
__________________
Intel 7600K @ 4.5Ghz - Asus Strix Z270I - Asus Strix GTX 1050 Ti - 16GB HyperX 2400Mhz - Samsung 250GB 960 EVO / 500GB 850 EVO - Corsair AX750 - Phanteks Evolv ITX - Corsair H80i V2 -
Acer Predator XB240H - Corsair K65 / M65 / Void Wireless / MM300
Wakka is offline   Reply With Quote
Old 9th May 2017, 12:36   #13
Concrete-Coffin
Supermodder
Yeah been a great buy got it a few weeks after they fixed the sata problem on the boards so that's easy 4+ years ago
__________________
Old 9th May 2017, 13:56   #14
bawjaws
Mod Master
bawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyan
It's probably also an indictment on how games have stagnated in terms of CPU utilisation.
bawjaws is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
