Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 7th May 2017, 17:06   #1
numanoid
Mod Master
numanoid's Avatar
numanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for president
Cant install windows on my new pc
Hi again guys, ive just formated the ssd, stuck my windows disk in and nothing all i get on the screen is "running mode 1.1.2 cannot find required map name. Press esc in 1 second to skip startup.nsh,any other key to continue"... Its stuck on that screen no matter what i do, a reboot shows the same, cannot get into the bios, any ideas guys
numanoid is online now   Reply With Quote
Old 7th May 2017, 17:17   #2
Big Elf
“not another f—-ing elf”
Big Elf's Avatar
Big Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming Saiyan
Can't you remove motherboard battery to reset BIOS?
Googling suggests that resetting BIOS will resolve it.
__________________
Case Labs TH10│Asus Rampage III Extreme│Core i7 990X│24GB Corsair Dominator GT│GTX Titan SLI│Samsung 850 EVO 256GB│Crucial M4│2TB Samsung Momentus x 2│SeaSonic P1000W│EK Supremacy│EK FC-RE3│EK-FC Titan SE x 2│EK-RAM Dominator│Black Ice SR-1 480 x 3│Swiftech 35X2
Big Elf is online now   Reply With Quote
Old 7th May 2017, 17:25   #3
numanoid
Mod Master
numanoid's Avatar
Thank you mate, trying that now, thanks
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
