Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 9th May 2017, 10:39   #1
Concrete-Coffin
Supermodder
Concrete-Coffin's Avatar
Concrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming SaiyanConcrete-Coffin is a Super Spamming Saiyan
4770k msi z87 gd65 gaming guides
Any help would be great trying to get my head around the new bios loads more settings to play with any decent guides
__________________
I5 2500K @ 4.2ghz l GA P67A UD4 B3- F7a BIOSl 8GB corsair 1600mhz l rx 480 8gbl CM 690 II advance l corsair H60 l F3 1TB Spinner l crucial M4 128 SSD l 650w evga GQ l
Concrete-Coffin is offline   Reply With Quote
Old 9th May 2017, 14:21   #2
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
There's not much to learn over the 2500K to be honest. The only new thing is the introduction of the input voltage due to the FIVR (Fully Integrated Voltage Regulator(s)) on the CPU which Intel thought was a good idea... and the introduction of the cache multiplier/voltage.
I'd say you should start at 1.3 volts and 45x on the CPU multi, leave the cache at stock as it is a pain to clock and does not gain you very much at all. See if it is stable, just like you would with your Sandy chip, and then adjust it accordingly. 4.5 at 1.3v shouldn't be too much to ask, but some chips can't do it. Any ideas what the previous owner had it running at?
Oh, also, do NOT check it with the latest Prime that has AVX included. It will add 20c+ to your temps. Test it with Prime 26.7 or something near to that.
__________________
Gamer: ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480 8GB | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv Tempered Glass | Win 10 Home | CM Masterkeys Pro L | Logitech G502 | Logitech G920
Ultrabook: ASUS ZenBook UX305F
TheMadDutchDude is offline   Reply With Quote
Old 9th May 2017, 14:39   #3
23RO_UK
Hasta Maņana
23RO_UK's Avatar
23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan
As per what Brendan has said, no games use AVX neither do 90% of professional applications so it's a pointless exercise running the version of Prime with it included.
23RO_UK is offline   Reply With Quote
Old 9th May 2017, 14:55   #4
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
this is a fairly comprehensive guide. But as MadDutchDude says, not much is different from Sandy/Ivy.
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is offline   Reply With Quote
Old 9th May 2017, 14:58   #5
Yadda
Vegan Sandwich
Yadda's Avatar
Yadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming Saiyan
I did a bit of research when I first got my Haswell refresh 4690k. I use a z97 board but I don't think there's all that much difference.
These are the "limits" I worked from.
CPU input voltage: max 1.9v. My I5 is happy at 4.5GHz with a input voltage of 1.85v, but needs 1.89v for a stable 4.6GHz.
CPU Vcore: max 1.3v for safe 24/7. My I5 needs 1.29v for a stable 4.6GHz.
Don't bother with overclocking the cache until you've found your optimum core overclock, and even then it's not really worth the bother. I think I've got my cache up to 42x at 1.15v but tbh it doesn't make any noticeable difference.
__________________
Lost a Duff, gained a Charlie.
i5 4690k @ 4.6GHz / ASRock Z97m OC Formula mATX / 2x8GB Crucial Tactical DDR3 @ 2200MHz C10 / EVGA GTX 780 @ 1200/6400MHz / BX100 250GB SSD / Seagate 2TB SSHD / Nepton 240m AIO / EVGA 600B PSU / Corsair Carbide Air 240 / Win10 Home / 1080p monitor / Logitech MOMO wheel
Yadda is offline   Reply With Quote
Old 9th May 2017, 16:33   #6
Concrete-Coffin
Supermodder
Cheers lads for the info will see what she can do with 1.3v
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
