Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 9th May 2017, 15:01   #1
keenan
Supermodder
keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.
Sabertooth X58 and M.2 drive via pci-e adapter. Possible?
Hi everyone in the know..
I recently bought a Lite-on 512gb M.2 for a Ryzen build that sadly didn't happen.
So, I want to use this M.2 drive in my current X58 mother board via a M.2 to pci-e adapter like this..
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
Would it work?
__________________
Project Marshlands
keenan is offline   Reply With Quote
Old 9th May 2017, 15:46   #2
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Doubt you'd be able to boot from it but I don't know that for sure. It would probably work but might depend on the motherboard / PCIe lanes and then what else you had plugged into other PCIe slots.
GeorgeK is offline   Reply With Quote
Old 9th May 2017, 16:09   #3
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
Originally Posted by keenan View Post
Would it work?
Short answer: Most likely not
Longer answer: X58 doesn't support NVMe [which iirc the lite-on drive is], and as most x58 boards are BIOS rather than UEFI there's no way to bodge support on like with some later boards.
If it's the AHCI model [the CX1 iirc], it might work, but it's a lottery as to whther you can boot from it or not.
If it's a SATA model it won't work with the adaptor.
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is offline   Reply With Quote
Old 9th May 2017, 17:35   #4
keenan
Supermodder
Thanks for the info guys..
I know the drive is AHCI, but I dont know how to tell if it's a SATA model?
The M.2 is this one in the pic (Lite-on CV3 8D512)
http://www.svethardware.cz/forum/att...3&d=1474838004
__________________
Project Marshlands
Old 9th May 2017, 18:12   #5
RedFlames
RedFlames's Avatar
It's a SATA model. It says so on on the label. You can get converters that allow you to mount it like a 2.5"er but i don't know how reliable they are.
__________________
Old 9th May 2017, 18:14   #6
keenan
Supermodder
Aha, well spotted..
Is there a reason it wont work in an adapter? (Short but sweet answer)
__________________
Project Marshlands
Old 9th May 2017, 18:16   #7
sandys
Mod Master
sandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpit
It would work in an PCI express adaptor but not for booting I run an NVMe in my z77 which doesn't support NVMe natively. As mentioned if yours is sata, you'll need a sata adaptor not NVMe one.
sandys is online now   Reply With Quote
Old 9th May 2017, 18:16   #8
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
It will definitely work in the adapter as storage, but you may not be able to boot from it. The only way to find out is to try...
__________________
Gamer: ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480 8GB | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv Tempered Glass | Win 10 Home | CM Masterkeys Pro L | Logitech G502 | Logitech G920
Ultrabook: ASUS ZenBook UX305F
TheMadDutchDude is offline   Reply With Quote
Old 9th May 2017, 18:18   #9
keenan
Supermodder
Can you guys please let me know which adapters you are using?
__________________
Project Marshlands
Old 9th May 2017, 18:24   #10
RedFlames
RedFlames's Avatar
It doesn't matter, the PCI-E adaptors will only work with PCI-E M.2 drives, not your SATA model. You'd need a M.2 -> SATA converter like the one I linked above.
Or sell it on and buy a 2.5" SATA SSD.
__________________
Old 9th May 2017, 18:41   #11
sandys
Mod Master
This will give you both
https://www.amazon.co.uk/PCIe-SATA-P.../dp/B01M8L0JLD
or this
https://www.amazon.co.uk/dp/B01MXHIH5Z?psc=1
Old 9th May 2017, 19:14   #12
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
I bought an M2 drive before for a build I was doing. It was 64gb. Any way, turns out I had an MSI board that you could not fit an M2 to only a wireless card (very odd board) and so I bought something like that ^ but cheaper and it's still going strong now. I use it for my Linux machine on a Phenom 2 and it boots as an SSD would
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 9th May 2017, 22:08   #13
keenan
Supermodder
So woth something like this it will be powered by the pci-e slot, but I would still need to connect the SATA cable to the motherboard right?
https://www.amazon.co.uk/slots-NGFF-...ds=M.2+to+sata
__________________
Project Marshlands
Old 9th May 2017, 22:18   #14
RedFlames
RedFlames's Avatar
as far as i can tell, yes
__________________
Old 9th May 2017, 22:48   #15
keenan
Supermodder
Thanks for all the info. That ultimately beats to whole purpose then..
I'll just sell it and try to recover what funds I can..
__________________
Project Marshlands
Old 10th May 2017, 11:21   #16
mrbungle
Undercooked chicken giver
mrbungle's Avatar
mrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyan
I use one of those with a Sata m.2 drive.
Works very well, just pick up a super short sata cable.
__________________
//5930K//Gigabyte X99 SLI//16gb DDR4//Asus 480X Strix 8GB//HX1050w//
mrbungle is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
