Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 12th May 2017, 18:21   #21
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Suck air in would be my preference. What other fans do you have in the case and which way are they blowing?
GeorgeK is online now   Reply With Quote
Old 12th May 2017, 18:33   #22
Kronos
Another grumpy old git.
Kronos's Avatar
Kronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming Saiyan
I have two in the front sucking air in and two on the top taking the air out. I have room for two thin fans in the floor also.
__________________
Carbide 240/Asus Z170M plus/I5 6600K @ 4.6Ghz/Avexir Core Blue Series 16GB /AXP 200 Muscle /Gigabyte FE 1080/500Gb OCZ TR150 SSD/2 x 256Gb SSD/ 2TB HDD/ SST-ST60F-P PSU/Dell U3415/CM TK White (browns)/Logitech G400s/.
Silverstone GD05B/ MSI B751A-E33/G840/2x2GB Crucial Ballistix DDR3 Red LED/GTX 260/Kingston 60GB/500GB WD/Corsair CX500/Dell U2711/ E Element Chroma KB /Logitech M518.
Kronos is offline   Reply With Quote
Old 12th May 2017, 18:38   #23
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
In that case 100% sucking air in - otherwise it'll be fighting against the other fans - keep the direction constant
Old 12th May 2017, 18:38   #24
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Originally Posted by Kronos View Post
It has been confirmed bu a couple on the Evga forums so looks like I will buy.
One question though should the fan suck air from the front of the case or blow air out?
You can run it either way. I would replace the EVGA fan it's hella noisy.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 12th May 2017, 18:43   #25
Kronos
Kronos's Avatar
Cheers George.
I was obviously aware if that hence my question. Thanks for the tip about the noisy fan. I have my PC next to me and like the quite I currently have with the fans installed.
__________________
Old 12th May 2017, 21:16   #26
Vault-Tec
Vault-Tec's Avatar
Yup just use your existing fans at their existing speeds Glenn. Should be more than capable enough without all of the racket
__________________
MUWC Winner ROTT
Old 13th May 2017, 10:52   #27
Kronos
Kronos's Avatar
Yet another question, I would like to log temps over the next couple of days whilst gaming so that I can get an idea of temps. I have CAM installed as I have a Hue plus and that tells me that my GPU has reached 80 but this software is very buggy so looking for other suggestions for software that I can have running that will keep a log and that I can view on a second monitor whilst I kill and maim.
So looking for software suggestions please.
__________________
Old 13th May 2017, 11:04   #28
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
I'd have to have a look when I get home but I think MSI Afterburner creates log files that you can open in Excel / Open Office etc
Old 13th May 2017, 11:06   #29
Kronos
Kronos's Avatar
Spooky as I was just looking at that particular bit of software. Cheers George.
__________________
Old 13th May 2017, 11:11   #30
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
Great minds think alike eh?
Old 13th May 2017, 11:12   #31
Kronos
Kronos's Avatar
Or fools seldom differ.
__________________
Old 13th May 2017, 11:27   #32
Kronos
Kronos's Avatar
I think I am going with MIS Burner and CPU-Z as they both save a log.
__________________
Old 13th May 2017, 11:50   #33
Kronos
Kronos's Avatar
Found it on Amazon for 20 less, might have to wait a bit for it though. Anyone see any problems with buying this instead of using Scan?
https://www.amazon.co.uk/gp/product/...QXNCLV8H&psc=1
__________________
Old 13th May 2017, 12:07   #34
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
As it's sold by Amazon US is there a chance of you getting hit for 20% VAT when it arrives in this country + 8 Royal Mail handling charge? Not sure how that works with Amazon imports.
Old 13th May 2017, 12:09   #35
Kronos
Kronos's Avatar
If you place your mouse on the green Global Store it says "Sold and shipped from abroad. All import customs duties and taxes included at the time of purchase." Which hopefully means that the charges you mention are not incurred?
But thanks for the heads up as I tried to understand the Global Store T&C's but gave up and have emailed Amazon for final price clarification.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
