Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 13th May 2017, 10:09   #1
hairyknacker
Multimodder
hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.
Mini itx mobo needed- help please!!!
Can anyone recommend me a decent mini itx board- preferably for an i5 chip- which has both 4x sata and display port please?
I have been asked to build a new NAS type enclosure and need something to do this with as I already have some stuff but not a motherboard. It is really to be used as a media based server with a huge itunes movie collection running itunes solely as I cant get a dedicated NAS to stream the DRM itunes files. Drives are currently 6 3.5" WD Reds, Seagate Archive drives- mixture of drives but would need to be all together in a JBOD type configuration or will have to play around with the library settings in itunes so it can see and use the individual drives
Budget- low as possible but would spend as much as needed within reason!
Thx
hairyknacker is offline   Reply With Quote
Old 13th May 2017, 10:46   #2
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
Have you already got the chip, and if so, what is it?
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is offline   Reply With Quote
Old 13th May 2017, 13:56   #3
hairyknacker
Multimodder
Was looking fer a z170 board but sorted now
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
