Displays Blurry text on secondary monitor.
Discussion in 'Hardware' started by Kronos, 13 May 2017.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    Just set up a secondary monitor and noticed that the clock was blurry, moving an open GPU-Z box over to the screen it to is blurred. I have it connected by DVI should I switch to HDMI, or is there a setting I am missing?
    Second monitor is a Dell U2711 with a resolution of 2560 x 1440, primary monitor is a Dell U3415W with a resolution of 3440 x 1440.
    Edit.It looks like a Windows 10 scaling issue which was supposed to be sorted in the Creators update.By changing the resolution to 1360 x 768 makes stuff readable but is not ideal.
  2. Spraduke
    Spraduke Lurker
    23 Sep 2009
    Check its not applying any under/over scan at the native resolution.
    Sent from my HTC One_M8 using Tapatalk
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    How do I do that mate?
  4. TheMadDutchDude
    23 Aug 2013
    Is it just a single or dual link DVI cable? It needs to be dual link. :)
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    You may have hit it.
    Edit; Only had one dual DVI in my massive bag of video cables and that gave no image, must be faulty, bunged a HDMI in and all is well.
