Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 13th May 2017, 14:29   #1
bdigital
Is re-building his PC again
bdigital's Avatar
bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.
Wireless Gaming Headset Recommendations
Hi all,
I fancy getting a half decent headset for gaming. I have a budget of around 120 (but happy to spend less!).
I would like wireless, but with the option of wiring up if battery is low. There seems to be loads of decent options from the likes of Logitech, Razor, Corsair, Steelseries etc.
Thought I would see if there are any that come highly recommended from BT
I am not an audiofile, I just want good quality sound, good quality mic and comfort.
Thanks
__________________
My photography website: http://www.polarityphoto.co.uk Please share! || Follow me @polarityphoto on Twitter|| My Flickr ||Facebook||
Check out my Apline White TJ07 - Case Mod and Water cooled build. http://www.flickr.com/photos/6188486...7631486959032/
bdigital is offline   Reply With Quote
Old 13th May 2017, 17:23   #2
GTIgeneral
Supermodder
GTIgeneral's Avatar
GTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming Saiyan
Not sure about wireless but I currently own the HyperX Cloud 2's, best headset ive owned and have a really solid construction compared to most of the "gamer" headsets ive tried. The cloud's are considered the best for the price from what I've seen in loads of reviews
GTIgeneral is offline   Reply With Quote
Old 13th May 2017, 18:40   #3
bdigital
bdigital's Avatar
Thanks GTI general, I will check them out.
Can anyone here vouch for thee SteelSeries Siberia 800?
https://www.amazon.co.uk/SteelSeries...ct_top?ie=UTF8
__________________
Old 14th May 2017, 09:26   #4
Jimmy6
Multimodder
Jimmy6 is the Cheesecake. Relix smiles down upon them.Jimmy6 is the Cheesecake. Relix smiles down upon them.Jimmy6 is the Cheesecake. Relix smiles down upon them.Jimmy6 is the Cheesecake. Relix smiles down upon them.Jimmy6 is the Cheesecake. Relix smiles down upon them.Jimmy6 is the Cheesecake. Relix smiles down upon them.Jimmy6 is the Cheesecake. Relix smiles down upon them.Jimmy6 is the Cheesecake. Relix smiles down upon them.Jimmy6 is the Cheesecake. Relix smiles down upon them.Jimmy6 is the Cheesecake. Relix smiles down upon them.Jimmy6 is the Cheesecake. Relix smiles down upon them.
Yes - I have 1 and am about to buy another for downstairs. V comfy (subjective), but I love the sound, battery life and connectivity. Plenty of reviews on the internet that back me up. But they are expensive. No Bluetooth - if that's a problem try the 840s.
__________________
Intel 6700K // Asus Maximus VIII Hero Alpha // 32GB 3000MHz Corsair DDR4 // MSI GTX1080 // 512Gb Samsung 950Pro M2 // 1Tb Samsung 850Pro // Custom EK loop // Dell 2711 // ROG Claymore Core // Corsair M90 //
Jimmy6 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
