Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 17th May 2017, 11:52   #1
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Wraith Spire or NH-U9DXi4
Morning all
I'm thinking of building a Ryzen - probably a 1700 or maybe a 1600 (both non-X) - server / workstation to replace the two servers that I currently run and can't decide about the cooling. I'll definitely be overclocking but maybe not running a max overclock at all times.
It's going to be housed in a 4U case that I have for space reasons and also as I'll have a lot of drives plugged into it (at least 10 or 11, maybe more) which limits my cooling options somewhat. The case has fairly good airflow from 2 exhaust fans at the back and 3 fans on the midplane controlled by a fan controller.
Cooling options that I've narrowed it down to are either
1) The stock Wraith Spire cooler, which by all reports is actually very good - cost £free with the CPU.
or
2) A Noctua NH-U9DXi4 for which I would have to purchase an NM-AM4 bracket as it's not eligible for Noctua's free bracket scheme - cost ~£55 after buying both the cooler and the bracket.
There are obviously no direct comparison reviews of the two out there and only a minimal number of reviews of the Noctua cooler and none of which on Ryzen.
Thoughts?
GeorgeK is offline   Reply With Quote
Old 17th May 2017, 12:16   #2
Wakka
Yo, eat this, ya?
Wakka's Avatar
Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.
If you're getting the Wraith Spire with with the CPU anyways, why not just try it out and see how it does before dropping cash on another cooler?
Or is swapping it out once everything is in and running such a ballache that £55 up front is better value?
__________________
Intel 7600K @ 4.5Ghz - Asus Strix Z270I - Asus Strix GTX 1060 - 16GB HyperX 2400Mhz - Samsung 250GB 960 EVO / 500GB 850 EVO - Corsair AX750 - Phanteks Evolv ITX - Corsair H80i V2
Acer Predator XB240H - Corsair K65 / M65 / Void Wireless / MM300
Wakka is online now   Reply With Quote
Old 17th May 2017, 13:12   #3
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
That is a fair point - I am normally quite keen to get a build up and running and then leave it but the 4U case is ridiculously easy to work in - you just slide off the top and then everything is readily accessible. Kitguru's review of the 1700 and the Wraith Spire does mention that the included thermal paste is exceptionally sticky and is liable to pull the CPU up out of the socket when removing the cooler however.
Old 17th May 2017, 13:51   #4
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Then just loosen it off, run the PC for a few minutes and then gently twist. That always worked for me, and I have been using Cerqmique which is really sticky for many years
From what I've heard the stock cooler does OK.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
