Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 17th May 2017, 15:27   #1
CrapBag
I Mod, Therefore I Own
CrapBag's Avatar
CrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming Saiyan
Can't update BIOS
I'm trying to upgrade my friends PC a little after his old gpu died.
I have installed a brand new GT 610(he doesn't play games) and upgraded him from 2gb to 4gb of ram (DDR2 800mhz), also added two new fans as his were well loud and will probably stick a better cooler in if it will fit.
I have kindly been given an E8400 by Arboreal to replace his lowly E2160 cpu but I need to upgrade from the F3 bios to the F9 bios.
I have downloaded the correct one from Gigabyte but every time I try and update with Qflash I just get the message, Bios ID check error and it stops trying to update.
Anyone know what I'm doing wrong?
His board is a GA-P31-DS3L.
CrapBag is offline   Reply With Quote
Old 17th May 2017, 17:43   #2
lancer778544
isnt really an ultramodder...
lancer778544's Avatar
lancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyan
Crappy, are you using Qflash through the BIOS (hit the END key on startup I think) or via Windows?
__________________
Intel Core i7 6700k | Asus Z170-Deluxe | 16GB Crucial Ballistix Elite | MSI GTX 970 OC | 256GB Samsung 840 Pro | 1TB Seagate Barracuda | Corsair AX860i | CM Storm Trooper | Creative Sound Blaster Zx
lancer778544 is offline   Reply With Quote
Old 17th May 2017, 18:29   #3
CrapBag
CrapBag's Avatar
Qflash in the bios
Old 17th May 2017, 21:42   #4
CrapBag
CrapBag's Avatar
No one got any ideas, in a bit of a time crunch as it's my friends only pc and I have had it for nearly a week and was hoping to give it back tomorrow.
Old 17th May 2017, 21:46   #5
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
Is it AmiBIOS? If so, you can get a Windows tool which will rewrite the whole BIOS - I'm sure I saw a similar issue on an ASUS board.
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is offline   Reply With Quote
Old 17th May 2017, 21:53   #6
CrapBag
CrapBag's Avatar
It's Award
I've always been a little wary of window bios utilities as the only time I've ever used one it bricked my mother's mobo.
Old 17th May 2017, 22:06   #7
jinq-sea
Moderator
jinq-sea's Avatar
Humm - never done an Award one in Windaz, but I think I'd give it a go in Safe mode. Else, could you get a chip from eBay?
__________________
Old 17th May 2017, 22:48   #8
CrapBag
CrapBag's Avatar
Not sure what to do know, really don't want to kill his now working pc.
A chip from ebay is an option but I don't really want to spend any more on a ten year old pc.
I'll add these pics here in case in helps
Old 17th May 2017, 23:32   #9
jinq-sea
Moderator
jinq-sea's Avatar
I'd probably have a crack at the windows tool. But I'm an idiot
__________________
Old 18th May 2017, 02:04   #10
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
Is there a different revision of the motherboard? If so, try that.
Secondly, you only need F6 for Yorkie chips. Start there failing everything else.
__________________
ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480@RX580 8GB with VRAM strap mod | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv TG | CM Masterkeys Pro L | Logitech G502 | Logitech G920 | ASUS ZenBook UX305F
TheMadDutchDude is offline   Reply With Quote
Old 18th May 2017, 07:22   #11
CrapBag
CrapBag's Avatar
Edit
Seems it didn't like the 2 previous USB sticks I was trying, changed to a brand new one and it flashed straight away.
Go figure, grrrrrrr.
Old 18th May 2017, 13:22   #12
TheMadDutchDude
Flying Dutchman
They might have been formatted incorrectly. I forgot about that. I'm glad you've fixed it.
__________________
Old 18th May 2017, 13:51   #13
CrapBag
CrapBag's Avatar
I did check to see if they were FAT which they were but I think they were both bootable at one time so I don't know if that made any difference.
Old 18th May 2017, 14:15   #14
jinq-sea
Moderator
jinq-sea's Avatar
Me too - and on reflecting on it, I think I've had the same issue in the past!
__________________
Old 18th May 2017, 15:49   #15
CrapBag
CrapBag's Avatar
Well it seems to be happy with its new E8400 and GT 610 which is good.
Old 18th May 2017, 20:35   #16
Arboreal
I *am* a Dremel
Arboreal's Avatar
Arboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming Saiyan
Good news, perseverance paid off The E8400 rides again! Glad I could help
In other news, my LAN buddy has killed his Z77 mobo and HD 7870, so your friend's not alone.
My spare mobo (Q67) won't run Ivy CPUs, so he can't test his i5K to see if it's alive or try his 'new' Radeon 270x from Gumtree
Arboreal is offline   Reply With Quote
Old 18th May 2017, 21:12   #17
CrapBag
CrapBag's Avatar
Pc was running lovely and quiet (for 80mm and 92mm fans), loaded it into the car on the back seat, get to his house, hook it all up and suddenly the front 120mm fan is making a racket ffs.
Seems like I might need to replace that one now too .
Thanks again Arboreal, I have officially thanked you on my wanted thread
Old 22nd May 2017, 01:51   #18
modd1uk
Mod Master
modd1uk's Avatar
modd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyanmodd1uk is a Super Spamming Saiyan
Plenty of 120mm fans kicking about if you don't have one fella, just say the word and I'll lob one in the post FOC.
__________________
Originally Posted by Nexxo View Post
Report him for being a dick. Which should be a criminal offense IMO.
Originally Posted by Gareth Halfacree View Post
There you are, then! Buy 100, take two, eBay a bundle of 98 at 70% the price of the 100-bag bundles, spend the profit on ale and whores.
modd1uk is offline   Reply With Quote
Old 22nd May 2017, 02:13   #19
CrapBag
CrapBag's Avatar
That's really nice of you.
I was going to give him an old hiper one , I have here but I booked it up to a PSU and that's a bit rattley and whiny so not much​ use.
If your happy to send one that would be great.
I'll pm you in the morning if that's ok.
Cheers
Old 22nd May 2017, 02:15   #20
modd1uk
Mod Master
modd1uk's Avatar
Cheers
Drop me your address fella and I'll get it in the mail today / tuesday. Got some brand new ones that have been ripped out of cases so I'll send one of those, should do nicely.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
