Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 19th May 2017, 13:15   #1
LePhuronn
Multimodder
LePhuronn's Avatar
LePhuronn has yet to learn the way of the Dremel
Crimping tools clarification
Hi all
Can somebody offer me a clarification on crimping tools please? Might save be a bit of cash.
I'm putting 2pin Dupont connectors onto some LED strips so been looking at Dupont ratchet crimpers. Easy enough, and they're all listed as model SN-28B that can crimp 2.54mm pitch pins onto 28 to 16AWG wire. For example:
http://www.ebay.co.uk/itm/271969275056
Now, I know that pitch is spacing between holes, rather than thickness of a pin, but Molex Mini Fit Jr pins are also 2.54mm pitch, and those are the pins we use for PSU cables. And Molex crimp tools also list 28 to 16AWG gauge wire as its crimping range
Now, if you Google SN-28B crimp tool you'll get a link to moddiy's "Professional Molex Crimping Tool" which is pushed as Molex crimper, yet has model SN-28B and shows a picture of crimping Mini Fit Jr, fans and Dupont crimps.
https://www.moddiy.com/products/Prof...nFFBoCOw_w_wcB
Are these the same thing?
So, the question is this: can I crimp Dupont and Molex Mini Fit Jr with the same tool? It would save about £10 to dispense with a Dupont crimper and just get a decent Molex one. Conversely, it would save about £40 to dispense with the Molex crimper and just use a highly-rated Dupont crimper.
Although I'm not making PSU cables yet, I will be pulling the trigger on the Dupont stuff soon, so I'd rather get my tools correct right now.
Cheers!
__________________
Project: ASTERIA II: Rearmoured
In Win 901, case mod, watercooled | Modding update nominee April 2017
LePhuronn is offline   Reply With Quote
Old 19th May 2017, 15:12   #2
LePhuronn
Multimodder
LePhuronn's Avatar
Oh, I forgot. On a related topic, is this 18AWG wire suitable for PSU cables?
http://uk.farnell.com/alpha-wire/305...-5m/dp/2290834
I'm getting a few bits from Farnell so I thought I'd save the hassle and get wire too whilst I'm there.
__________________
Old 19th May 2017, 16:59   #3
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Yep. Same product. ModDIY has sn-28b on the handle in the pictures even. The professional crimpers are ridiculously expensive. Probably because NASA-types just buy what they need without shopping for the cheapest. So THE Dupont crimper (SN-28b) is $150, and crimper sn-28b is $20.
Wire: If i'm reading this right, that wire is soldered strands. It has a high enough voltage rating, but it will be pretty stiff. I did Bloo with stiff heavy-gauge speaker wire. It was impossible to get the 'lumpy' look out of the cables.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 19th May 2017, 17:19   #4
Big Elf
“not another f—-ing elf”
Big Elf's Avatar
Big Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming Saiyan
The SN28B isn't brilliant for crimping the Dupont pins but it's reasonable for the Molex mini fit Jr pins with a tendency to crush the pins but not too badly, I modded mine to stop that.
I use the Molex 63811-1000 hand (rather than ratchet) crimp tool for Dupont pins and fan pins but it's expensive for limited use and a pain to use for Molex mini fit Jr pins due to the lack of a ratchet mechanism. You may find long-nose pliers easier to use for the Dupont pins
18AWG cable is generally OK for PSUs but you need to watch out for avoiding overloading the 4 pin Molex type connectors for peripherals as only 1 wire carries the 12V supply. That wire is tinned and shouldn't be too stiff for your use.
__________________
Case Labs TH10│Asus Rampage III Extreme│Core i7 990X│24GB Corsair Dominator GT│GTX Titan SLI│Samsung 850 EVO 256GB│Crucial M4│2TB Samsung Momentus x 2│SeaSonic P1000W│EK Supremacy│EK FC-RE3│EK-FC Titan SE x 2│EK-RAM Dominator│Black Ice SR-1 480 x 3│Swiftech 35X2
Big Elf is offline   Reply With Quote
Old 19th May 2017, 17:37   #5
LePhuronn
Multimodder
LePhuronn's Avatar
Thanks to you both.
I have 20 Dupont pins to crimp compared to a full PSU of Mini Fit Jr. so I'll just make do with something like long-nose pliers and put my money into a proper ATX crimper.
As for the wire, there didn't seem to be anything suitable in standard copper wire that wasn't 3+mm overall diameter, single core or 1000ft rolls. Thought I'd ask anyway.
__________________
Old 19th May 2017, 23:40   #6
Cheapskate
Cheapskate's Avatar
I'm usually the guy to say just roll with long nose pliers, but after doing one PSU set like that, I decided never again.
__________________
Old 20th May 2017, 23:59   #7
LePhuronn
Multimodder
LePhuronn's Avatar
I "only" have 20 Dupont pins to do so if I can't get a crimper that will do both I'll invest in something decent for the Molex and just crimp the Dupont with long nose pliers. or take a gamble on the £8 Dupont crimper.
__________________
Reply
Tags
crimp, dupont, molex
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
