Reply
Thread Tools View Mode
Old 19th May 2017, 18:59   #1
CircularCore
Multimodder
CircularCore's Avatar
CircularCore has yet to learn the way of the Dremel
CCM-Concept 01
Hi all, welcome to my new project , the CCM-Concept 01
My idea is based on the Thermaltake X71 tempered glass.
The MB tray will be replaced by a sheet of 10mm plexiglass, on the latter with the help of a CNC will be carved out of 6mm ducts going to form a custom reservoir directly on the MB tray of the case.
Externally I will change the front and the top grid, again with the help of CNC I'm going to carve a different design, it will also set up a midplate / lightbox with all my sponsors name engraved with laser.
Sponsor:
Alphacool
Apacer
Thermaltake
Asrock
First render:
CircularCore is offline   Reply With Quote
Old 20th May 2017, 12:37   #2
CircularCore
Multimodder
MB tray complete
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
