Build Advice VMWare ESXi Server Build Advice
Discussion in 'Hardware' started by N4N01D, 25 Sep 2012.
  1. N4N01D
    N4N01D What's a Dremel?
    29 Apr 2004
    Hi folks,
    Not been round here in a while and have lost touch with the new formats SSI EEB & EATX etc.
    Hopefully someone would be able to verify the following hardware (all which should be on the VMWare HCL).
    1x S7056GM3NR Motherboard - Tyan S2011 SSI EEB
    2x CM8062101038801 CPU - Intel Xeon E5-2630, S2011, Sandy Bridge, Six Core, 2.3GHz, 15MB Cache, 95W, OEM
    1x TJ07 Case - Silverstone TJ07 Black
    2x CFP52B Case - Silverstone HDD Cage
    2x FP58 Case - Silverstone DVD Bezel
    8x CP05 Case - Silverstone HDD Backplane (I have some SATA drives already)
    2x SDP08 Case - Silverstone 2.5 to 3.5 Adapter
    1x SOD02 DVD - Silverstone Slot DVD
    2x NH-U9B SE2 Heatsink - Noctua NH-U9B SE2 CPU Cooler (Socket Intel 2011)
    2x CT3K8G3ERSLD81339 Memory - Crucial 24GB kit (8GBx3), 240-pin DIMM, DDR3 PC3-10600 memory module
    2x ERV1250EGT PSU - Enermax Revolution 85+
    2x SSD - Samsung 256GB 840 Pro (When avail)
    3x ST2000DM001 HDD - 2TB Seagate ST2000DM001 Barracuda 7200.14 SATA 3 6GB/s 7200rpm 64MB Cache 8ms OEM NCQ
    1x MRSAS9240-8I/SGL Raid - LSI MEGARAID 8PT SAS/SATA 6Gb/s PCIE RAID
    3x GT-120-1850 FAN - 120mm Scythe Gentle Typhoon 1850 RPM Cooling Fan
    2x LSI00258 Raid - LSI00258 - LSI CBL-SFF8087-SATASB-10M 1m Mini-SAS (SFF-8087) to SATA fanout with sideband)
  2. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    Will this be in use for a work system?
    Any reason for not using hyperv 2012?
    Space requirements
    Number of NICs required?
  3. Guest-16
    Guest-16 Guest
    3x DIMM not 4? No ECC?
    1.35V is nice but I don't think that kit is designed for LGA2011.
  4. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
  5. N4N01D
    29 Apr 2004
    Cheers guys wasnt sure if I'd get any answers here on server stuff!
    @deathtaker27 - It will be for a VMWare ESXi training rig, I was planning on running 2x nested ESXi and 1x vCenter/iSCSI to show vMotion etc. NICs/Space wont be a problem since its only training
    @Bindibadgi - That memory (DDR3 PC3-10600 • CL=9 • Dual Ranked • x8 based • Registered • ECC • DDR3-1333 • 1.35V) is ECC and IIRC its 3 dimms per CPU. I checked the Mobo Manual and for RDIMM x8 DR EEC 1060/1333 it can be upto 8GB per DIMM. 1.35v - I'd just searched the systemboard model number and that was one of the kits returned, do you think that was a mistake?
    @mm vr - Its only a test rig and as ESXi (free) has a limit of 32GB it would be overkill at the moment. I have an old tbalancer that I was thinking of running with the 1850rpm fans or have they changed the connections on the fans (iirc it was 3 pin)? Do you rate the Seasonic better than the Enermax (TBC I've not come across Seasonic before)?
    Thanks again folks!
  6. mm vr
    18 Nov 2007
  7. Guest-16
    Guest-16 Guest
    http://www.tyan.com/product_SKU_spec.aspx?ProductType=MB&pid=753&SKU=600000269
    X58 was 3 DIMM
    X79 is 4 DIMM
    You CAN run 3 just fine (or 2, or 1, or 8), but you're missing a memory channel :)
  8. N4N01D
    29 Apr 2004
    Oops I'd skipped to the last page and saw they were both 9.7 :D
    Also nice that its cheaper than the Enermax too!!
    Ahh good call, I hadn't picked up on that change :)
  9. N4N01D
    29 Apr 2004
    I guess the options are - http://www.tyan.com/manuals/S7056_UG_v1.0a.pdf Page 42
    4x 8Gb (2x 4GB) Kits
    Dual Rank x8 1333
    Single Rank x4 1333 (Supported but not validated)
    Dual Rank x4 1333
    Quad Ranked (Supported with limited validation)
    Which would you go for as the costs are the same?
