Graphics Upgrading an ageing system.
Discussion in 'Hardware' started by freshsandwiches, 7 Dec 2014.
  1. freshsandwiches
    freshsandwiches Can I do science to it?
    9 Aug 2009
    Hello,
    My graphic card is not working any more (artefacts on boot screen, now disabled) and is pretty much not fit for purpose now anyway so I'm looking to replace it.
    I have a few concerns though as a new card would be going into an ageing system. I'm only running a core 2 duo. I was considering sticking a q6600 in.
    Question number one would be what is the best CPU upgrade for my board?
    The second question would be what would be a sensible upgrade for the GPU? I want to avoid bottlenecking where possible.
    Given the time of year a full upgrade is out of the question. I'm looking to squeeze what I can from my current rig.
    My full current spec is in my sig.
    FS
  2. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    What's your total budget? You should be able to get a Q6600 for around £20 these days and I think someone was price checking a Q9550 recently, which would be about as good as it gets on s775. In terms of GPUs, it really depends on what your remaining budget is.
  3. freshsandwiches
    9 Aug 2009
    I'm prepared to spend what it takes to keep this rig running for the foreseeable, whilst being realistic.
    I'll have a look at the Q9550.
  4. freshsandwiches
    9 Aug 2009
  5. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I know you're not looking for a full upgrade, but you may be able to pick up some older x58 1366 stuff for REAL cheap at times second hand. Definitely more worthwhile investment than spending more on old 775. Then pick up used 570, 660 or somesuch and be good to go.
  6. freshsandwiches
    9 Aug 2009
    While this makes sense, I genuinely don't have the time. Plus I'd hate to consign all my old stuff to the loft.
  7. silk186
    silk186 Derp
    1 Dec 2014
    Try overclocking the q6600 for practice and if it's still holding you back keep an eye out for a q9550. I've guessing that you could find an i5-750 for a good price as well as since many buying second hand would want a i5-2500k or newer.
  8. phuzz
    phuzz This is a title
    28 May 2004
    Personally I'd go for a graphics card now, even if it's bottlenecked it'll still be plenty fast. then save up for a mobo/cpu/ram upgrade.
  9. freshsandwiches
    9 Aug 2009
  10. freshsandwiches
    9 Aug 2009
    Think I might go for the 750ti.
  11. modd1uk
    modd1uk Multimodder
    4 Sep 2006
  12. loftie
    loftie Multimodder
    14 Feb 2009
    Look at the R9 270, overclockers has one for £115, think scan at £120. Pretty sure it's supposed to be faster than the 750ti.
    edit :^or that if you're going that high
    Edit 2: Yea it is better http://anandtech.com/bench/product/1080?vs=1130
  13. mrbungle
    20 Sep 2004
  14. freshsandwiches
    9 Aug 2009
    I'd have bit your hand off mrbungle. Sorry things got hectic and I stopped checking the thread.
    Thanks for the info loftie. I'll be considering both nVidia and AMD cards from now on.
    I can't make my mind up. I think I might go as cheap as possible to tide me over. 2nd hand an option.
  15. mrbungle
    20 Sep 2004
    Have a look at overclockers.co.uk, they have 7850 and 7950's refurbs for cheap.
  16. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    If they're compatible with your board it's worth checking out the Wolfdale chips. Something like an E8400 or E8500 are very capable dual core chips. The older quads tend to sell for more than they're actually worth in terms of performance.
