Hardware Thermalright Macho 90 and Macho Rev. B Reviews
Discussion in 'Article Discussion' started by Combatus, 30 Sep 2015.
  1. Combatus
    16 Feb 2009
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    Like the Macho B, but purely for cosmetic reasons, having a large window on my case (Corsair 450D), I couldn't live with the B&W colour scheme of the fan, and those clips look like they wouldn't fit with anything else, and I don't like fans that extend beyond the dimensions of the cooler itself..looks untidy.
  3. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    The clips look like standard ones to me ...
  4. amagriva
    amagriva Minimodder
    13 Jun 2009
    I think the Macho B could go fanless if you don't overclock
  5. wst
    wst Minimodder
    30 Aug 2009
    I think my Frio will have to suffice a while longer, I'm glad that Thermaltake have still got air coolers of a similar philosophy (huge, millions of fins) in their lineup. Even if they're 200g lighter ;)
  6. blackworx
    blackworx Cable Wrangler
    31 Jan 2008
    I'm running an original Macho fanless on an i5 3570K with a mild overclock. There's also a fanless HD7750 in the box. All airflow duties done by a single 12cm Noctua in the roof (P182) running at just above stall voltage. Works very well and is utterly inaudible even when gaming. Granted, it's no powerhouse, but the Macho really is an outstanding cooler.
  7. Xir
    Xir Modder
    26 Apr 2006
    Ah....now there's a selling arguement :D
  8. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    It looks really Macho. Without madness of Noctua DH-14/15. With such beefy heatsink I think it should do just fine as passive cooler. Certainly for anything up to i5.
Tags: Add Tags
