Case Mod - In Progress eNVy - Custom Parvum, 5960x, GTX 980s
Discussion in 'Project Logs' started by MunneY, 16 Feb 2015.
  1. MunneY
    MunneY What's a Dremel?
    10 Feb 2015
    HOWDY!
    So, its about that time of year again when I get the itch to build something. This build has actually been in the planing stages for about 3 months, if not more. I am going to keep certain parts of the build secret until i get to the point where I reveal them. You can expect the full compliment of pictures to be done, along with Videos where I can. There definitely will be one done on the case, and one for atleast 2 other parts :-D
    I don't yet have the case in hand, but I do have most of the core components. I'm still waiting to hear back from a couple of people to wrap this up. Did I mention that this build is Sponsored!??!?!
    HUGE Thanks to the following people - Parvum, EVGA, Mayhems, xD3aDPooLx Customs
    Main Components:
    Motherboard: EVGA X99 Micro
    CPU: Intel 5960x
    Memory: 16GB of something
    GPU: 3x EVGA GTX 980s
    PSU: Undecided
    SSD: 1TB SSD
    Watercooling Components:
    Still working on this, but here is a list of what I'll be using
    CPU Block: UNDECIDED
    GPU Blocks: GTX 980 Blocks ( MUST BE CLEAR )
    Radiators: 4 x 240mm
    Pump: UNDECIDED
    Tube Fittings: Probably Bitspower
    Other Fittings (Misc): UNDECIDED
    Tubing: 16mm Rigid PETG
    Coolant: MAYHEMS! Probably Aurora 2
    Other Components:
    Fans: Parvum F1.0
    Cables: xD3aDPooLx Customs Fully custom paracord
    Lighting: Unsure at the moment.
  2. Hukkel
    Hukkel James' minion
    20 Dec 2012
    A double wide Parvum case.
    I DIG....
  3. MunneY
    10 Feb 2015
    UPDATE TIME!!!
    So for this build I wanted to have monster power in a mini package, Enter the EVGA X99 Micro. Pairing this with a 5960x is going to give me all the power I could want and the form factor to keep everything compact.
    So, without further delay!
    These last few pictures are also VERY VERY important. They will bring to light the first of the big surprises of this build.
    Three Full Size PCI-E 3.0 Slots... in all their X16 Glory!
    And the actual surprise?!
    Thank you guys for your support. Can't tell you how much it means to me. None of this would be possible without ya'll
    And a HUGE thanks to [@]EVGA-JacobF[/@] and the EVGA Team!
  4. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    Very interrestig build.
    Custom Parvum looks really awsome.
    Will you hack up the Rear IO of the GPU´s or will you use a Flexible risercard to move the 3rd card one slot ?
    Tri Sli will be just x8,x8,x8 according to EVGA Homepage but still plenty of grunt as its pcie3.0.
  5. Impatience
    Impatience Minimodder
    6 Apr 2014
    Or watercooled? It is a Parvum case.. So watercooling cheesecake would look good! Plus then the cards are only single slot!
  6. phem0r
    phem0r What's a Dremel?
    14 Feb 2011
    Looks similar to a mountain mods style case, i like it. Good luck!
  7. MunneY
    10 Feb 2015
    Thank ya! I'll be busting out the dremel for this one! The cards will be watercooled so I wont have to fuss with the cooler.
    The cards should run at 16/16/8 per my conversations with EVGA. Once they get on there I'll find out for sure though!
    You got it.
    Thank ya... Yeah, that double width does give that appeal!
  8. saxovtsmike
    12 Aug 2008
    It´s a pity that all mondern GPU´s seem to have the double DVI stacked.
    If they woudn´t have them stacking GPU´s would be easy done when watercooling them.
    Good luck with hacking the DVI connector into pieces.
  9. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Subbed for some cube lovin'!
  10. MunneY
    10 Feb 2015
    Just a lil teaser...
  11. MunneY
    10 Feb 2015
    Soooo... Since this thing is now happening
    I might be ditching the GTX 980s......
  12. MunneY
    10 Feb 2015
    I got a little sneak peak from Parvum this morning.
    Apparently part of my case is playing Goat Simulator :-D
  13. Bartacus
    Bartacus Minimodder
    30 Oct 2014
  14. MunneY
    10 Feb 2015
    The King is dead... Long Live The King
  15. saxovtsmike
    12 Aug 2008
    two titan x. wow
    ouch.
    Did you get a good price for the unused 980s or did evga exchange them ?
    At least you do not need to chop a GPU Backpanel when drowngrading to 2way sli instead of tri-sli.
  16. GeorgeK
    18 Sep 2010
    Can you resize your photos please - some are too large at the moment by far...
  17. MunneY
    10 Feb 2015
    Sorry, I was under the impression it auto resized them. It does on my screen.
    When I get home tonite I'll try to shrink them down.
  18. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Me want them TitanX's...please. :D
    Can't wait to see more.
  19. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    The pics are too big because there's 24GB of VRAM in them. :D Insanity!
  20. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Does this change build plans for the case? You'll not be needing this 6 pci slots anymore. Cant wait to see what two Titan X's will do! Got your order in with EKWB for blocks?
    J.
