News ARM/x86 hybrid PC announced
Discussion in 'Article Discussion' started by CardJoe, 13 Sep 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    I want one just because of that name!
  3. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    This sounds way too computicated...
  4. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    Could get people to transition over to Linux more, and reap the power benefits, especially on battery powered devices.
  5. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    Why am I getting Amiga x86 expansion card flashbacks?
  6. wyx087
    15 Aug 2007
    basically have a smart phone level of processor embedded into your desktop for full desktop use....... it's not ready yet.
    wait for Cortex A15 and then simply build an instruction decoder to decode x86 commands, and promote use of Linux for full speed.
    or instead of trying to give full desktop experience, off load things to the ARM chip as a co-processor. of course, a smartphone SoC won't be needed then.
  7. memeroot
    memeroot aged and experianced
    31 Oct 2009
    I super-glued my phone to my pc and connected the usb port
    home mod's rule
  8. capnPedro
    11 Apr 2007
    2 CPUs 1 CUPP?
  9. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    I think I'll wait until Microsoft get their own Arm based OS together or a real ARM based PC than this hybrid. The principle idea is good, but hybrids of any sort having always been somewhat flakey, so I think I'll be passing on this hybrid too.
  10. Gareth Halfacree
    4 Dec 2007
    The daft thing is: this has already been done. All modern x86 processors are RISC at heart, and have an abstraction layer that allows them to pretend to be CISC.
    The chances of Intel or AMD letting ARM at its abstraction layer are, of course, "a snowballs in hell's."
    I laughed.
  11. wyx087
    15 Aug 2007
    that's why i suggested it, it'd be much more transparent, and if it allows us to access the RISC instructions, we could see more optimised programs.
  12. DocWolfe
    DocWolfe What's a Dremel?
    21 Mar 2009
    Stolen from The Reg :/
    From what I've heard Microsoft has plans in the works to introduce ARM support in it's mainstream operating systems.
  13. Cogwulf
    Cogwulf What's a Dremel?
    30 Jul 2010
    It would be great if this could be engineering so that the ARM processor handles background tasks, while the x86 CPU handles all the more demanding tasks. So you would have the benefits of multi-core processors, but without the cost and power demand of just adding more identical cores.
    Currently those background tasks just use a small fraction of a modern x86 processors power, but that 1% or so of CPU usage takes up an entire processor. Taking an 'asymmetrical' approach to parallel processing would be much more power -and- cost efficient than the "more cores is better" approach
  14. sear
    sear What's a Dremel?
    2 Aug 2010
    This would be negligible if it wasn't for the fact that you can alt+tab between the two machines. That feature alone makes it worth considering, even if just for the enthusiast market.
  15. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    @Cogwulf: That sounds to me like a short-term solution for lazy coders. What we need is better parallel coding i.e. programs that take full advantage of multiple cores.
    Another good thing however is to adapt your idea and have cores that can reduce their power usage when they aren't needed as much. Intel already have this, it just needs to be more adaptive to cover cores that are only partially used as well as ones that aren't active at all.
  16. Lazy_Amp
    Lazy_Amp Entry AMD Engineer
    17 Jul 2010
    I'd like to know what state of idle the x86 core is when you are alt-tabbing. Sure, you can have both going, but how much power are you saving if you are working on the ARM but still have windows running?
    Would also be interesting to have a TINY SSD for a linux boot drive for the ARM and a FAIRLY SMALL Win7/XP SSD for the x86, plus a shared HHD.
    Reminds me of that... I believe it was a foxconn Mobo that had an integrated Atom processor along with a 775 socket. I like the idea of shared HD space. Too bad the price was far too high and was outclassed at launch by cheap x58 systems
  17. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Sounds like a kludge without any real purpose. With both processors running you're just burning more power without any real advantage.
    Does anyone know how Windows CE was put together? MS has some experience with the ARM architecture through that and while I don't know how difficult it would be, it's a starting point. It would also have the advantage of a more restricted hardware base and so a stripped down version of Windows for ARM Seems like it has a lot of potential.
    What ever happened to Via's new CPU (Eden?)? The Via low power chips seem like exactly the right answer for this sort of thing, but they haven't caught on.
  18. Saivert
    Saivert Minimodder
    26 Mar 2005
    so it is just ARM which is seen as a competitor to x86 CPUs now? what about PowerPC? is that just dead and remaining a IBM high performance computing CPU?
    Also the x86 chip in this hybrid will obviously go into a low-power halt state of some sort when using the ARM chip. I doubt it will even need much power at all. You guys have the ability to think for yourself you know.
    Anyways, even if you get Windows for ARM all applications would need to be recompiled for ARM which would take a while. Most open source or free software would be quickly ported across but huge software packages would take longer. Granted this is a non issue in the long term but it had to be said. Seems like some of you think it is just flipping a switch over at Redmond.
    And yes Microsoft has lots of experience with multiple architectures. Windows NT was available for MIPS, ALPHA and PowerPC in addition to x86.
  19. Elledan
    4 Feb 2009
    PowerPC is in XBox 360, Cell (PS3) and the Wii. It doesn't seem to have a future in desktop or portable areas ATM. IBM seems much more interested in POWER.
    MIPS may turn out to be a competitor, since China seems to have picked that to become its national CPU (Longsoon) architecture. We'll see.
  20. Cthippo
    7 Aug 2005
    If it's so capable of going into such a state, then why have the ARM at all? Intel touts their low power tech, but nowhere will they cite numbers. Historically the difference between full load and idle power on mainstream CPUs has not been very great. If the Intel could drop to a very low power state when operating, then why add the ARM?
    How many "huge software packages" are you going to run on a little mobile ARM ultra-portable?
    Troll much? :nono:
Tags: Add Tags
