I'm struggling to find the type of QDC's that I'm looking for. I'm looking to run the QDC through a bulkhead, but as soon as it passes the bulkhead, it needs a 90 degree angle to clear the radiator. Preferably I would be able to directly mount a 90 degree compression to the QDC as soon as it leaves the bulkhead. However, I'm finding it hard to locate QDC's with an internal thread to mount the compression. Here is a diagram: Does anyone have any ideas? Cheers
Only thing I can think of is to use a normal bulkhead fitting with a 90º compression on one side, a straight compression on the other with a short length of tubing going to a QDC. Trouble is it'd be long and ugly.
Cheers mate. I've managed to sort it out with this... https://www.koolance.com/water-cooling/product_info.php?product_id=946 this https://www.koolance.com/water-cooling/product_info.php?product_id=880 and this http://www.scan.co.uk/products/phob...ce=google+shopping&utm_medium=google+shopping
