Planning HTPC Scratch Case
Discussion in 'Modding' started by Xye, 29 Jan 2012.
  1. Xye
    Xye What's a Dremel?
    21 Nov 2010
    This is first mod exclusively on this site, I used do alot over a OCN under the same username.
    Hardware is pretty much already bought I just need to sort out all the connectors.
    Also the front panel still remains undone As I have not yet decided on its design,
    Some Initial Renderings:
    And if anyone is interested I did a 3D PDF Here for Download outer shell removed so the layout inside can be seen.
  2. KidMod-Southpaw
    28 Sep 2010
    That looks really cool. Nice and sleek, and if put into practice with the right amount of brushed aluminium, you'll have a great case!
  3. Xye
    21 Nov 2010
    I was thinking (and Designing for) Black plastic to suit the rest of the stuff and the TV.
    I'm hoping to put a USB and an Illuminated logo on the front.
  4. KidMod-Southpaw
    28 Sep 2010
    Just remember that it is a HTPC, make sure the lights are subtle. :)
  5. Xye
    21 Nov 2010
    My Plan is/was to have the front made of thisTinted acrylic then have the logo design cut out of a piece of black plastic behind it.
  6. KidMod-Southpaw
    28 Sep 2010
    What colour light will you be putting behind that? It should be nice as long as the light isn't too bright.
  7. Xye
    21 Nov 2010
    With the blue tint I was thinking just white. I'll probably have to use resistors to dull it down enough.
  8. KidMod-Southpaw
    28 Sep 2010
    5V white LED's are available I think. They'll look good.
  9. Xye
    21 Nov 2010
    Probably only need one or two to get the desired level of brightness.
    As I said I need to sort out the wiring as to how I'm going to power all this and make the cables tidy. I need some custom cables for all this.
  10. Xye
    21 Nov 2010
    Ok Here is my initial idea for the from panel:
    I may change the blue tint for a smoked acrylic but the renderer makes it look kind of weird. The two dots infront of the dragon are going to be the Power and HDD activity lights...
    What do you think?
  11. Xye
    21 Nov 2010
    Any thoughts?
    Trying not to make it look so boxy in Version2:
  12. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    I like V2 more personally, the rounded edge is minimal, but does quite a bit for the design :thumb:
  13. Xye
    21 Nov 2010
    Thanks.
    To be honest sometimes I lack inspiration for the details of a design.
    I've just realised I was also going to put a USB port on the front and no reset button.
    I'm struggling to find a USB port that can be attached, and also a smaller reset button.
  14. Combatus
    16 Feb 2009
    The curve makes it for me too - the fact the front and roof are one section makes it look sooooo much better, not that original was bad!
  15. Xye
    21 Nov 2010
    Thanks.
    I'm still pretty much in the design stage for the outside of the case. The insides are pretty much fixed unless someone can find a better way of arranging them.
    This weekend I'll spead a little more time trying to refine the design and post back here with some renders.
