Scratch Build – In Progress Raspberry Pi Competition - The 'Golden' Wet Pi. *Finished with final Pictures*
Discussion in 'Project Logs' started by Phame, 19 Feb 2013.
Coolant colour?
  1. Blue
    10.9%
  2. Green
    6.9%
  3. Yellow
    5.0%
  4. Pink (Raspberry Colour)
    60.4%
  5. Red
    16.8%
  6. Purple
    6.9%
Multiple votes are allowed.
  1. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Hello guys,
    I will be building a scratch case for the RPi and also watercooling it. The block will span across the three main hot spots of the board. I also know there is no need to watercool it, but I like to do something alittle different and hopefully have a Pi to put in it! ;)
    Why am I doing this project?
    I hadn't been on bit-tech forum for a while, and was one day browsing the site looking for inspiration to get me to mod/build a new case. I came across Combatus post about the competition, the first thing that came to mind was... "why not watercool this thing?" - That became a problem, as I started to look at jrs77 (thanks by the way) model of the RPi and throw some modelling ideas on CAD, it quickly became apparent that the thing was alot smaller then I first anticipated. Not to worry I thought, il give it ago so thats where we are.
    Things to be done:
    - Re machine the new designed for waterblock. DONE
    - Polish the acrylic for the top of res. DONE
    - Cut the acrylic for the top of waterblock. DONE
    - Polish the waterblock and res with 1500, 2000, 2500 grit WnD. DONE
    - Cut the Pi board holders. DONE
    - Tap the waterblock M1.6. DONE
    - Turn down some hose fittings DONE
    - Gold plate all the aluminium DONE
    - Powder Coat the Raspberry Pi holders DONE
    - Assemble and test DONE
    - COMPLETE THE WET PI. DONE
    --------------------------------------------Raspberry Pi--------------------------------------------
    Watercooled Raspberry Pi :D
    Hopefully the first one in the world?
    Waterblock:
    Here's a picture of the waterblock, latest picture!
    Radiator:
    Water tight test.
    The dims for the block are: 98.5 x 70.0 x 17.0mm and made of Aluminium and acrylic. I will be gold plating the Aluminium on both the rad and waterblock.
    Pump:
    This is the pump that will be used for this build, http://www.micropumps.co.uk/
    Shirty likes this.
  2. Shirty
    18 Apr 1982
    How deliciously extravagant.
    I assume you've already watercooled your smartphone? :hehe:
    I'll be watching this one eagerly.
  3. Phame
    17 Sep 2012
    That was a quick reply! :D
    Cheers dude! :thumb:
  4. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    a watercooled pi? this is awesomely riduculus but i'll watch for sure! :D
  5. White-Fox
    White-Fox What's a Dremel?
    11 Feb 2013
    holy s**t dude :D i am truly waiting more from this! good job.
  6. Phame
    17 Sep 2012
    Cheers guys! :thumb:
    Won't let ya down! :dremel:
  7. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    How exactly is the radiator removing the heat from the loop? It looks just like another water block.
  8. Phame
    17 Sep 2012
    Its similar to having another waterblock but with an added heatsink type configuration machined into the back with possibly a fan to deplace the heat, if there is any!
    Loved Acronym by the way! :)
  9. jrs77
    jrs77 Modder
    17 Feb 2006
    Let's talk about overkill :p
  10. Cheapskate
    13 May 2007
    -All for a prize that costs less than a meal at the local fast-food shop.:lol:
    That's the kind of crazy, gung-ho, madcap thinking that brought me here in the first place. Glorious!:D
  11. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    Hoooooooooly sh*t.
    This is the pure meaning of overkill.
    But this is gonne be awesome :D
    You could try to overclock it, the cooling should be fine :p
  12. Phame
    17 Sep 2012
    :D - Cheers for the time you took to do that model dude.
    I know its only cheap :blush: but being eXtreme is why we enjoy doing these things right?
    I think the gold plating is going to be more expensive then alot of Pi's. :D
    Thanks dude, I will overclock it just for you ;)
  13. elAwesome
    1 Nov 2012
    Yaaaay :D
    A 5Ghz Raspberry...:jawdrop:
  14. tekonivel
    tekonivel Minimodder
    14 Jul 2012
    Awesome! I was just thinking that some one should do watercooled Pi. And I start browsing the forums and here it is. Will be following this like a hawk.
    Also good luck for the competition.
  15. Phame
    17 Sep 2012
    I think the max is 1GHz but il have a go! ;)
    Thats what I was thinking when I first saw the Pi comp. Thankyou dude..
    Loving Bulky by the way looks scchweeeet! :D
    Little update ive changed the Rad/Res render below.
    Will be machining this up in abit when the CNC has finished cutting a tool.
    :D
  16. NoobNeb
    NoobNeb Enthusiastic Lurker
    14 Nov 2011
    New design is much more apt :thumb: enough renders already though let's see some metal action :p
  17. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    Ha! Love it!
  18. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    From the rad i thought you were gonna use orang and blacks loop to cool it. That wouldve proven to be quite interesting :p
    Overkill is awesome :thumb:
  19. faxiij
    faxiij Minimodder
    25 Jan 2011
    yup, couldn't agree more.
    looks like we have a winner for the comp now...given you finish this. :worried: :wallbash:
    completely insane, completely stupid and nuts, totally overkill, fully bonkers. and thus....completely awesome. :rock: :rock: :rock:
  20. siliconfanatic
    10 Sep 2012
