Looking for some SP fans, all black if possible with no leds or anything for a rebuild of a machine. Will be controlled by Aquaero 6 and would prefer not to use Corsair SP fans
Perhaps if you gave reasons why the SP series are no good it will narrow the list of possible alternatives?
Not a question of them not being good but I need black fans- blades as well, with no leds and I think that Corsair only have white blades with leds edit: Ignore me- just seen some
To follow on from Big_malc, if they don't do a black ring, at least you can easily remove it and paint it black. Or if you're using the fans in a pull configuration then the ring will be hidden behind the rad.
