Case Mod - In Progress Prodigy Casemod : Final 08-21-2013
Discussion in 'Project Logs' started by saxovtsmike, 18 Sep 2012.
  1. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    After a little Introduction of my work done till now including a bit of an overview over my watercooled LianLi A05 here is what I´m up to at the moment.
    Please excuse some spelling mistakes and other grammar stuff, I´m from Austria (skiing no Kangoroos, that sentence I used quite often in the US of A) 34 Years of Age, I´ve a nearly 3 year old son and I´m a Software Engineer.
    First of all, Big Thanks to Bitfenix Germany for giving me the opportunity to work on their marvelous Prodigy case.
    As the Project title will make you guess it will be another boring Red-Black-White styled R.O.G. Themed casemode, as there were allready so many average ones, and a view good ones.
    Well I´ve to live up with that, and I can only give you my promise that I´m going to do my best.
    Well wait a moment, R.O.G. Themed Build in a Prodigy someone might ask, just to be certain, it´s going to be an ITX build, no crappy crunched in Asus Gene something.
    :confused:
    It wasn´t my plan to do what I´m going to do in the first case, because I was following the EVGA Z77 Stinger itx boar since the first rumors and previews. Thx to twitter and EVGA´s Jacob
    As there is no sign of a release Date, I went back to things I knew, so it had to be tha Asus P8Z77-i Deluxe.
    As the casemod is ROG themed I´m going to mod and style the Mainboard as good as I can into something that Asus should have done by themselves.
    Making a propper Z77 Maximus Gene ItX.
    Now what´s that for a name ?
    As this will task will take some time do fullfill in a propper way, I really havent looked in specific hardware details, like choosing a CPU,GPU, Ram and cooling.
    I just took the stuff I got cheap and the rest will be decided when it´s time to make decisions.
    So the Hardwarelist at the moment is quite short, an nothing like Fixed
    Mainboard : MAximus Gene IX (P8Z77-i-Deluxe)
    Ram : second hand 4gig Reaper Kit
    Cooling : second hand Corsair H50
    The second mayor Part of this Project involves the second name-giving Item, a White Bitfenix Prodigy.
    Speaking of that, I think there is no need to bore someone with Pictures of a fully assembeld Case or an unboxing story.
    But what I can tell you is what I´ve in plan for the case.
    First of all Windows on both sidepanels. With a mainboard orientation like in this case :D you have to show gpu and cpu side.
    I´ve allready marked the maximum size for each window, which is limited by the PSU Housing/Mainboardtray
    Next after that the Tray will get some opening on both sides to the PSU , on top to reduce contact chances of a cpu backplate to the tray, and towards the front I´ll open the tray for more access in case of a modular psu and its plugs.
    After removing the top and bottom Wobblebars (pls. tell me a propper name for them) a really cute case was left. Really like that :D
    Apart from the remaining holes which are found after removing the bars.
    I just did that as I have an idea to follow which ended in a small 3d sketch :
    The first draft of my top wobblebar replacement.
    The cut out will be done to fit the original Mesh cover to keep a littel oem style.
    Heightwise I´m planing 2 types.
    Type A, the slim one with about 30mm in heigt, to house and hide 2 fans which would be for an Aircooling setup, a below mounted Radiator, or a top mounted slim Radiator
    Type B woulde be about 50mm in heigth and would house a top mounted 45mm Radiator.
    What can be mounted for the top, Can also be fitted as a replacement for the bottom wobblebars.
    To keep it simple that would only work as a Case Feet bracket with an option for Additional IO Ports which would look somewhat like
    or a 3.5" fan controller/Aquaero, or just a simple Mesh. So many options to look at.
    While on cables and stuff, I really don´t know if this will be a sleeved build, Custom crimped cable lenght is a fixed point, no extentions, Hopefully I can find a solution for that ughly USB3 Header which is really short and I really don´t like the Idea where it should be plugged into. Well same thing is for the usb 2.0 ports on the Asus board.
    Finally there will be the question in which direction this build will go.
    As planed in a sleek, simple surfing office system, or as as expected :naughty: :naughty: in a full watercooled high end gaming rig, to replace my Gulftown system.
    Time will tell...
  2. AbKaRy
    AbKaRy What's a Dremel?
    1 Sep 2012
    Very interesting concept indeed ... Sub'd :)
  3. saxovtsmike
    12 Aug 2008
    Mainboard arrived at home.
    Tried to make some nice pictures of the delivery state.
    Seems like lots of work to do for me
  4. saxovtsmike
    12 Aug 2008
    Did the actual possible mods.
    Cleaned the Coolers
    De-Stickerd the Mainboard, oops void the Warranty after 2h of ownership :D
    Removed the useless Wifi
    Color Change of most of the blue parts of the Mainboard seem to be undoable without a soldering Iron, which is a mayor setback. Colorcoding with a permanent marker seems not to be the option I thought it would be.
    Time to get some Ideas while sleepin.
  5. whatsthatnoise
    whatsthatnoise What's a Dremel?
    21 Mar 2012
    You could try to "disassemble" a permanent marker to reach less accessible parts. Or a less adventures way, get some model paint (from Revell or something alike), a precise brush and lots of time and patience. :)
  6. KidMod-Southpaw
    28 Sep 2010
    The de- stickered board is beautiful!
  7. AciD_RaiN
    AciD_RaiN What's a Dremel?
    29 Jul 2012
    I'm planning a prodigy build next so I will be following this one closely ;) I believe in you mate :clap:
  8. LKummer
    LKummer What's a Dremel?
    31 Dec 2011
    Wait, ROG colors are red and black, and this motherboard is blue, so you are going to paint the coolers?
    And the moded board is looking great!
  9. saxovtsmike
    12 Aug 2008
    I don´t think that I´ve got the patience or skills to do that, so that that the outcome would look somewhere near the quality I would like to have it.
    Thanks alot to both of you
    THAT was the Original plan, but at the moment it looks like it´s not going to happen.
    Need to do a reconcept of the color scheme but there arent so many options avaliable.
    Silver/alloy are quite dominating next to blue. The white of the case itself is the next huge impact on the design.
    When not adding a 4th color I´m quite limited with my options.
    Getting the silver out of the equation would be probbably the easiest Task, but on the downside of that, the silver parts are the ones I like best at the moment.
    The plain silver from the caps in combination with the cleaned Heatsinks are quite pleasing
  10. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Looking good, will be watching as I have a Prodigy case that I might mod in the near future :)
  11. saxovtsmike
    12 Aug 2008
    Changed the Title because a R.O.G. styled P8z77 won´t happen.
    I´ll focus first on the metal work, and the mods done to the case.
    Future Hardware decisions in case of color choice will be done afterwards
    <sorry>
  12. saxovtsmike
    12 Aug 2008
    Dear Bit-Tech
    Did some work on the CAD system.
    Primary idea was to get pre-production Ready sketches for the windows, to get some quotes for them.
    Last, but not least, a closeup of a set of Replacement feet for the Prodigy.
    For an aircooling Setup this might be a Final revision too
    Should give the case a more stable stand on the table, and a little reduction in height.
    enjoy
  13. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Liking the renders dude, keep up the good work! :)
  14. saxovtsmike
    12 Aug 2008
    Tried the new ram sticks on the new mainboard...
    Seems that we have slight problem/issue for the support stuff :-(
  15. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    Yep, either they are a tad wonky, or im drunk! (And I am not a drinker. lol)
  16. saxovtsmike
    12 Aug 2008
    The Stinger has less space between the Ram slots than others, On the Asus z77 itx it looks good.
    Testfitted my Radiators, 240x45mm in top, 140x30mm in front.
    With a modfront the 120mm fans of the top radiator will fit inside, when I can move the 140 rad 5-7mm down compared to the actual Position.
    Finally it might even be enough space to fit my Aquaero5 below the 140 rad.
  17. saxovtsmike
    12 Aug 2008
    Thats gonna be the final loop
    Rear view, left and right of the Psu there will be holes for Quickcouplers (VL3N) to keep my Mora working at home
    Pwm Laing in its new home, some of the mobotray is missing
    Gpu Side, Ductaped hose goes out to the vl3n coupler, all the rest seems to be clear
    Coming from the vl3n quickcoupler up to the CPU waterblock (hopefully in a nice bend :D ) from the waterblock the fluid flows to the gpu near radiator entrance. As I´m using tygon leftovers, I had to cheat a bit from the rad to the res
    Plenty of space for the Aquaero, because mounting the top rad with one hole offset.
  18. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    looking god mate, i await updates eagerly
  19. Malketh
    Malketh What's a Dremel?
    22 Jan 2008
    Interesting placement of your res and pump! Did you look at EK's 140 res/pump top?
    Also, I love seeing a white Prodigy with that Asus board. I'm still working on modding my own and seeing a lot of the ideas I have mirrored here is kinda eerie. lol
  20. saxovtsmike
    12 Aug 2008
    I also own a Series one EK Xres/DCC Top. The new one looks thempting as I´d prefere the smaller Plexi cylinder of the "100" and has an input in the backside.
    Probably I´ll order a Plexi tube from the "100". With the actual solution I´ve far more options and I allreday had all the parts
