Motherboards So my computer died overnight.
Discussion in 'Hardware' started by monteur, 25 Aug 2014.
  1. monteur
    monteur What's a Dremel?
    11 Apr 2011
    As stated in the title my main rig does not do anything anymore when i press the power button on the case or board.
    Since i first suspected the psu , i hooked it up to my old system, which booted as normal.
    I already talked to my retailer since i still have 1,5 month of warranty on it, but he told not keep my hopes up, because the RMA with Asrock will take atleast 4 weeks or even 8.
    Here are my questions:
    1. Can i do a mainboard swap without reinstalling windows? plug'n'play?
    2. Can anyone recommend me a So.1155 Board? :)
    Thank you very much.
  2. Dark Matter
    Dark Matter Minimodder
    12 Mar 2010
    If it is a retail windows licence, should be fine to swap straight to a new board, sometimes may require a simple reactivation but otherwise should be straightforward.
    Budget for the board?
    Simon :)
  3. monteur
    11 Apr 2011
    Budget would be ~80€ , thanks.
  4. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Could also be the RAM or CPU even though it's very unlikely. Have you done the usual, eg:
    - check RAM modules one at a time, in all available slots
    - unplug from mains, drain PSU caps, remove battery for 15 mins, then try again
    - reseat CPU
    I wouldn't say motherboard was dead unless none of the above works.
  5. Nexxo
    23 Oct 2001
    I'm sorry for your loss. Now move on. :p
    On the upside: it's upgrade time! :D
  6. monteur
    11 Apr 2011
    i will run the suggested checks from LennyRhys and report back.
    Oh, nexxo you.. i'm already fighting that little devil in my ear. :D
  7. Yadda
    Yadda Minimodder
    25 Jul 2003
    I wouldn't be happy with the warranty situation, are you sure they aren't trying to fob you off?
  8. monteur
    11 Apr 2011
    trust me i'm not really happy about the situation here either.
  9. RagingMadman
    RagingMadman What's a Dremel?
    6 Oct 2012
    I would recommend Asus or GIGABYTE.
  10. monteur
    11 Apr 2011
    i ran all the suggested checks, still nothing.. dead silence.
    i'm going send it in first thing tomorrow.
    and nexxo might be right about a upgrade. :worried:
    can i keep my 8gb ddr3 ram for a socket 1150 board?
  11. monteur
    11 Apr 2011
    seems as if i can save some $ on the ddr3 :) im kinda on a tight budget right now for a upgrade but i need my rig. :)
