GT72 Cooling layout
Discussion in 'MSI UK' started by MSINotebookUK, 7 Nov 2014.
  1. MSINotebookUK
    MSINotebookUK What's a Dremel?
    29 Jul 2014
    The GT72 comes with a much improved dual-fan cooling solution compared to its predecessors. Thanks to advanced thermal engineering and features such as the thermal bridge (the heatpipe connecting the CPU cooling block to the VGA exhaust fins), the GT72 has a world-class cooling system. Anyone can keep a system cool by blasting the fans on max RPM, but the dual-fan Cooler Boost 3 solution also manages to keep the revs and thereby the noise levels down.
    As we already touched on a couple of weeks ago, we know that the temperatures never reach above 80°C, even with a grossly overclocked GTX 980M – the Cooler Boost 3 design you see above is the reason for this.
