News Microsoft officially retires Windows 8
Discussion in 'Article Discussion' started by Gareth Halfacree, 12 Jan 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. Cheapskate
    13 May 2007
    That had better be a typo, or I will be set to rage.
  3. David
    7 Apr 2009
    8 is dead, long live 7 :p
  4. Gareth Halfacree
    4 Dec 2007
    Typo, now fixed - ta!
  5. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    +1 :lol:
  6. azrael-
    azrael- I'm special...
    18 May 2008
    Is it possible to do a clean installation of Windows 8.1 (Update 1) with your original Windows 8 key these days? It used to be that you had to install Windows 8 first and then update to 8.1, at least officially.
    Not that I really care, for that matter. Windows 7 is still going strong on my pc and has no intentions of going anywhere.
  7. pre
    pre Minimodder
    24 May 2004
    Hah, still on 7 at home and work!
  8. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    It seems like only yesterday that I saw Windows 8 pop up on systems at local PC stores and I was all like 'nope' while admiring my pretty Windows 7 setup.
    I'm fine until at least 2020 :)
    Windows 7: the new Windows XP :D
  9. Guest-16
    Guest-16 Guest
    Unless they changed it very recently you have to install 8 first then 8.1 upgrade. It's really f'in annoying as I have an 8 key only.
    The fact they already killed 8 and suddenly class 8.1 as a 'service pack' tells me they're rolling out 10 as fast as possible with the intention of SaaS setup for OS like Office 365. It will certainly happen for business' - volume licensing will end as MS wants more control and repeat revenue, with the 'sell' that it'll be for security and reliability.
  10. azrael-
    18 May 2008
    Well, there's always the method of skipping entering the product key while installing Windows 8.1. Once installed, Windows 8.1 should happily accept a valid Windows 8 key. I just hoped these kinds of shenanigans were no longer necessary.
  11. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    i always used windows 8.1 USB install on laptops, if its an OEM system with the key burnt into the bios you can go straight to windows 8.1 (even if the system is windows 8 OEM system)
  12. tiger-moth
    tiger-moth What's a Dremel?
    26 Apr 2008
    And I'd be on 7, if it had native nvme support; but doing a clean install of win 7 on my nvme drive sounded painful, so my new build is on 10 (clean install with a win 7 key)
    But I'd rather be on 7
  13. Guest-16
    Guest-16 Guest
    Did not know - thanks!
