Project name :: Elite 130 Stacker Project by :: iD2 Hello, Today i'll show you my 2 PC case , 1st for my PC and 2nd for CNC Controller. Let start :: PS. I'm not good in English , If i make you confuse please feel free to ask me.
Need to move PSU for back to bottom. I do cut angle aluminum and drill cases with 2 hole for mountting angle aluminum and use it for hold PSU.
After move PSU to bottom , the heat was more higher than normal so i decide to bought "Samuel 17" & "Corsair SP 120".
I already finished connector back panel but it make my cases hot , So i decide to make new back panel by using piece of side panel that i cut it out. The new back panel will make my cases more cooler. PS. Connector back panel not show in this post.
When finish new back panel and after try to find my old 80mm fan , now i got one and add it to back panel.
This my old connector back panel that i already finished it before buy 2nd case. There connector will support 4 axis stepper motor , 1 e-stop , 3 limit switch.
And now finish it. But for CNC Controller i still not buy it , when i have an update about it i'll post it.
