SPONSORED BY Thanks to Alessandro from Ybris Cooling, Peter from EKWB, Luca from Ocaholic and Mike from Phanteks for the help! Happy New Year! After my first project, pics here, i'm starting the new year with a new worklog! Project Prime is based on a Phanteks case, the Enthoo Primo White Edition, it will be filled with 1x 360x60 + 1x 420x60 radiators, E22 hard tubing, and a full water cooled loop. The main colours are white, red and black. Hardware i7 4790K Asus Sabertooth Z97 Mark S Limited Edition Kingston HyperX Fury White 16gb Asus GTX770 DC2 Kingston HyperX 3K White Limited Edition RAID0 WD Caviar Green 2 x 2TB Seasonic SS-860XP2 Platinum + Icemodz.com Handmade Extensions Asus Xonar Essence STX Liquid Cooling Loop Radiators: Alphacool NexXxoS UT60 Full Copper 420mm - White Special Edition + Alphacool NexXxoS UT60 360mm Pump: Laing DDC T1 plus + EK X-Top V2 + EK-DDC Heatsink Housing Reservoir: EK-Multioption RES X3 - 250 White Edition WB CPU: EK-Supremacy Clean CSQ Plexy - Nickel WB GPU: EK-FC680 DCII Nickel Fittings: Bitspower Tube: Nanoxia CF1 PETG Hard Tube 12/10 mm Coolants: Nanoxia CF1 UV Red Accessories: 2x Aquacomputer Temperature Sensor Inline G1/4 + Bitspower Flow Sensor + Bitspower mini-valve Rheobus: Lamptron CW611 The case just arrived from Germany First, I've mounted PSU , HDD and SSD and I've started ordering the back, then I've moved to the front, mounting the motherboard , the supports for the cylindrical tank , the DVD Writer and the Rheobus. I've added 2 strips of bioadhesive to the reservoir supports to improve the grip. I've added two LEDs strips, connected to a single 12v case molex which allows me to on/off the lights of the 140mm frontal fans and LEDs. The case has a flap cover for the front bay 5.25, this makes it difficult to install a Rheobus which have knobs , but I managed to place my trusted Lamptron FC6 without problems. The space available in flip closed is about 3mm . I've started painting the fans and radiators in white for match the build. Final photo: Angel Vs Devil Bitspower Radiator Plate Some fitting photos Loop
UPDATE 1 Fans and Radiators installed next step: cpu wb and ddc top paint! UPDATE 2 DDC TOP, HEATSINK and WB BRACKET painted, i think they needs some red now UPDATE 3 wb cpu done UPDATE 4 Pump almost finished, I need to colour the engraved text on the top I used Plasti Dip Spray on the original ASUS GTX 770 DC2 backplate UPDATE 5 Finally , last Monday the tubes from E22 have been delivered to me directly from England! Today was the Slovenia turn, a package from EKWB I take this opportunity to thank Peter from EKWB, He will send me 5 of the new EK-CSQ Plug G1/4 (for EK-Badge) - Nickel for free because stop fittings were missed in my previous order, here a pic!
Banner update! A new sponsor. Thank Krystian from HyperX for the sponsorship! Some unboxing From Slovenia, Thanks Peter from EKWB for 5 EK-CSQ PLUG UT60 420 WHITE SPECIAL EDITION sponsored by alphacool and aquatuning.it
That's some awesome work on the fans, makes them look really sweet! I'll be interested to see how this turns out
Another unboxing today! Thanks Mundi from Icemodz.com for the sponsorship of these beautiful handmade extensions!!
I spent the weekend assembling the hardware, hyperx 3k raid 0 works great, But looks like 1 stick of ram is faulty, the pc won't boot with all 4 sticks mounted, i tried each one alone and i had fake boot with 1 stick, i will try to Contact hyperx for change this faulty stick. I also delidded the 4790k using the vice method and i have applied the Coollaboratory liquid pro on the die. Here some random pics
Love the fans, looks great. Will you be doing anything to the motherboard, such as decals, vinyl, or spray painting? Or do you plan on leaving as is?
I think the motherboard looks great as it is I Made a side cover, a 5,25 slot back cover and an hdd cover with plexyglass 3mm
