LiLi Tower Hi there, this build is already started begin march, but really wanted to let it see on bit-tech It's called the LiLi Tower. I've always had a kind of love for the Lian Li cubes Not one but two Lian Li PC-V351 One is new and the other one has some changes already First i wanna thank some sponsors of this build Mr. Freddy En Mr. Ruud Thanks to these guys my start is going to be a little faster and nicer. Thnx!!! The hardware - I7 920 D0 - 6x 2GB Corsair DDR3 1600 - 2 x EVGA GTX470 - Antec True Power Quatro-1000 - 2 x Aqua-computer Aquaero VF - Asus Rampage III GENE etc. Water cooling - 2 x Black Ice GT Stealth 240 Black - 2 x EK GTX470 waterblock - EK Supreme CPU block - 2 x EK-Multioption RES X2 - 150 Advanced - 2 x Swiftech 355 - Tygon slang - Bitspower Fittingen And more......... The color is gonna be black and transparent Some pics of the LiLi's Number 1 And number 2 Number 2 is a little modded already the top ia gonna be different, not with these fangrills This is the only thing i have from this Lian, but it's not bad. Have some nice ideas for this Number 1 is complete, this one is gonna be the bottum Psu and Hdd's gonna be under the motherboard The first idea was like this... But like this is better On top al the water cooling stuff is gonna be placed 2 rads, 2 reservoirs en 2 pumps. Last week i did some measuring and drilling the rivets Sawn a piece out of the 5,25 bay for the cables from the gpu Gpu in it, already did the sleeving Al of the remaining cables can be put behind the bay And these grilz will be put here with transparent fans with white leds Flipped the HDD bay, so now have space for 2 HDD's and a SSD Placed the motherboard tray, also flipped Nice slots for the cables This space is gonna be sawn out of the top. (formerly the bottom) The back is gonna be like this, but painted black and i need to get/make a plate for the gpu Always nice to get a new motherboard. A sweet little rampage The Asus Rampage III Gene fat box The motherboard Republic for gamers, for a non gamer 6 Slots on a small motherboard, i like it Fill it up, with.............. the EK-RAM Dominator Shiny installed it Using a EK-Supreme HF And 2 Black Ice GT Stealth 240 These are gonna be placed in the top Lian Fits perfectly Placed the motherboard in the lowwer Lian Not much space anymore, what is a good thing in this build And my 2 GTX470 in it Everything fits, in the top Lian i have a lot of space for the watercooling Now i needs to decide which reservoir i am gonna place This weekend i had a lot of sawning to do Almost nothing is left from the Lian The middle of the 2 Lians And the top of the Lian There gonna be 2 Aquaero's VF inside, for this 2 times a slot Put it al together and brainstorming again Made a little mistake, i tought that the aquaero,s where the same but the are different versions, So i had to drill the holes for the bolds again more to the left just a little bit different For the front 2 times a slot for the displays Had some Acryl covers for the aquaero, but the aren't the same color. So need to order 1 more The hole cover Made a acryl midplate. This times 2, one for the top and one for the midplate Did some drawning And drilling/sawning time Made holes for the cpu and the Rams and made a slot for the gpu's Removed the tape, needs to be cleaned And needs to straighten some lines, but this is the idea And the BP fillports, a total of 4. @ for the cpu and 2 for the RAM Second Lian on top, and more brainstorming. Coolermaster has givven me some nice stuff for my build A nice package with all kind of things 80mm fans with white leds A nice psu tester (sometime i blow things up) With upgrade units, for more load Black screws and other stuff A beautifull mouse, the Sentinel And....... the turbine masters which gonna be placed like this. Also i had some black aluminium panels, so lets get to work everything measured Drilled the holes And placed on the back mounted on the back And the fans for the radiators are finished Power up The are real quiet, and a lot of air And finally my acryl has arrived So sawn everything and drilled the holes Top left Top right Left Right And placed on each other Turned around On each side there's gonna be brushed aluminium. Th original panels i have finished already Left And right That's all for today Grtzzz.
Thanks you guys, for the nice respons. Like i said before, this project is started at the beginning of march, and i have 2 or 3 major updates finished allready. Today it's time to post these update,s. Hope you like these to After this update, i am almost at the same level of updating as i am today Brainstorming about the rads First i wanna to make some costum Brackets But dont think thats looks nice So i did something different, have maked a radiator tray Only need to Cut out 2 times a Rectangle for the airflow Made slots for the fittings Just like this Slots around the fittings Only need to connect the radiators together Some highflow fittings Looks nice i think And the one on the top The pumps are gonna be like this I did a lot of thinking about the reservoirs, and tried a lot of things I have spinbays, EK tubes 150 and EK tubes 250 Had taken some pics what i had tried The spinbays like this The 150mm tubes Or like this The 250mm tubes, but then horizontal Was getting crazy about this problem, but then............. Not horizontal or vertical, but in a inclined position From the top. Have a lot of space in the middle for the tubes Left side. Pump with a lot of rotary fittings Right side, almost the same as the left. Only the tubes gonna be with a different angle i did some small stuff. I've tested the airflow through the mesh It wasn't that good, so i've sawn a piece out of it Needs a paintjob 1 rectangle is bigger then the other one, this is because i dont wanted to see the suspension from the rads Also i had some Glostrings, nice stuff I hoped they where white, but they are bleu/green, but doesnt matter. Had to change my midplate Looks fine in the dark like this This is also coming in a vertical line in the front A nice glow, i think Purchased a FrozenQ reservoir. The blue one 2 reservoirs looks good, 3 even better Nice light in it Only i have 2 different colors blue, sow need to brainstorm for that And need to make something for the pumps Also i have sold my 3 GTX470, and get some other nice gpu's Gtx480, really nice cards Nickel blocks on it, looks better with this build Very shinny backplates The hole thing is really havy, so need to make something for this On the corners maked a kind of pilar I am in love with the backplates i had some nice stuff been delivered I think it,s the last stuff i need to finish this build, i hope So what did i get in: Some nice aluminium fans, the NorthQ 120MM 3711WL Silent Tornado And some BP fillporten Zilver plugs BP pluggen BP links Aqua computer powerbooster And 2 bottles of Feser Aqua ultra water The fans are coming across the motherboard, pulling fresh air over the board Like this Painted the back black And i have played with the glostrings, i did made it some more blue Top vertical line And vertical line under Nice effect on the inside Played with the different light sources, fans with the white led and some other leds Ram cooler also white leds in it Yesterday i did the front The 2 push buttons. One for the on switch and one for the eject button Sawn a piece of acryl. and maked 2 holes in it Placed the front plate The plex behind the front is gonna be enlighted, so that you have a white ring from the button and one around the button Also placed the new acryl front for the aquaero Made the aluminium strips for the 2 aquaero's Placed everything. I think i gonna make some cover for it almost finished the front Dont know if i make the buttons black, or leave them silver That's it for now Grtzzz.
This project is looking very nice. The work done so far looks very nice! I'll be keeping an eye on it, that's for sure
Hi k.3nny, thanks. Nice to see some Dutch pro modders here Yup, 2% of the Pbucket users had this problem I was one of them, but they solved this problem very nicely +1 for Photobucket
Ahh, more family members nice to know i'm not alone Thank you very much Because my pictures where offline for a while, i'm gonna treat you guys for another major update This time i couldn,t resist to fill the top section of my Lian The good thing of this build is that i can fill the both sections separate So i can do the leak test without my hardware under it, i had some bad luck with BP rotery,s in the past First i had al the tube in place, solid and flexible Turned the pumps, only need to make a nice bracket for this These connected with BP links For now connected with Tygon tube Did the same thing on the Other side Only a bit different for the higher placed radiator The FrozenQ res. also connected with BP links Nice in the middle And fill it up And yes, i had a leaking rotery under the reservoir not shocking, but need to exchange this Also placed some black fillports, just to see the looks of it Al the black fittings and fillports are also beeing exchanged by silver think it,s a nice effect, seems to be floating Dont forget the links between the gpu's Nice effect also is the illuminated edges from the slots Gonna be silver Placed the wc section on it and the other side with the gpu's also illuminated Using i bright white led Now everything is almost in place, i'am thinking to remove the FrozenQ reservoir. It's to much chaos, and to bright i think, so i have changed some big little things Removed the FrozenQ, just to get some peace in the upper section Instead of this i've made a piece of mirror acryl around the pumps to let it look like everything is one piece (The Tygon tubes are gonna be changed) Connect the pumps together, just for the looks. Has no function, but looks nice Just need to make a cover for the pumps Around the pumps the mirror acryl, for this i have cut out 2 slots to fit the pumps in Think this is much better with the FozenQ out. Now i made the top cover of the Lian Sawn the holes for the fillports and drilled holes Over this there's gonna be a aluminium cover, but i'm thinking about this for the shape Also been busy with my Be quiet psu. all the way black sleeving and give a little paintjob to the back And a little piece of me on the pic Always beautifull Mdpc quality sleev. In the 5.25 bay mch room to put all the cables The curve for the motherboard cables De curve van de draadjes naar de mobo voeding Just needs to be shapened Cpu cables true the 3.25 bays For the cables from the gpu's i used flatcable Just like this Like i said before, painted the back of the psu Gonna make a plate, just to get it the same like all the other covers Made the links for the gpu's I am still waiting for silver fillports. When they arrived i can put everything together, and connect all the cables to the 2 aquaero's But the most cables are covered for now That's it for this time. See you soon
