Case Mod - In Progress Red Candy
Discussion in 'Project Logs' started by montymole, 6 Jan 2014.
  1. montymole
    montymole Rigid Tubist
    24 May 2010
    I have had this case for 6 months now and whilst other projects are on downtime for various reasons i wanted to build a nice gaming rig that would take the warmer temps in my room and wanted to use up some hardware so went ahead with this here is a small build log modding will be kept to a minimum as this is really just a few days work some custom paint and some braided cables
    Case: Silverstone TJ07 Powder coated in White and Matt Black with 360 Rad mount in top
    Hardware:
    CPU: Intel i7 4770k
    M/B: Asus Maximus VI Formula
    SSD: Plextor M6e 128Gb for OS Samsung EVO 250Gb Games
    PSU: Corsair AX760 with custom E22 telios white and red cables
    Ram: Corsair Cominator 16GB 2133
    GFX: R9 290X
    Cooling:
    E22 Ultra Clear Hardline
    EK Blocks for the CPU, GFX
    EK White Dual Bay Spin Res
    EK D5 Pump and Top
    EK 480 PE Rad
    HW Labs 360 Stealth
    Bitspower Multi-Link Adapter G1 / 4 inch OD 12mm - Matte Black
    Mayhems Pastel Red
    5 x Phobya NB eLoop
    3 x Noiseblocker eloop
    Mods : really just the custom front grill and the custom paint work but this was not ever really about the modding side just wanted a PC that would sit on my desk and make me happy for the next year.
    My aim was to build something as clean and tidy as i could without taking up to much time as i am doing a project for someone else that is taking most of my time
    I will painting some parts to bring it all together here are some pics of what is going on
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    Painted Shroud on Maximus Formula VI
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    The R9 290X backplate painted
    [​IMG][/URL][/IMG]
    messing with my custom ROG logo
    [​IMG][/URL][/IMG]
    More to come later today :thumb:
  2. montymole
    24 May 2010
    Got some parts yesterday
    Bitspower 360 Radguard
    [​IMG][/URL][/IMG]
  3. Shurika
    Shurika Minimodder
    9 Mar 2012
    Oh, no, ASUS Formula waterblock is anodised aluminium, it could cause troubles if it have any scratch inside it, better to use only cooper waterblocks in all system
  4. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    This looks fantastic!
  5. jimbaw
    jimbaw What's a Dremel?
    8 May 2014
    as I've told you on facebook many times, it looks awesome! red and white builds for the win!
  6. montymole
    24 May 2010
    thanks for the positive response folks really happy with the ways its looking ill update with some more pics later
  7. snef
    snef What's a Dremel?
    18 May 2014
    I just love Silverstone 07,
    and it look really great in white
    you did a spectacular job on this build
    simply amazing
    montymole likes this.
  8. jimbaw
    8 May 2014
    forgot to say: definitely subbed!
  9. RetroDude
    RetroDude What's a Dremel?
    16 Nov 2010
    Gorgeous, gorgeous build
  10. sprintdmc
    sprintdmc What's a Dremel?
    16 Apr 2013
    Love the colour scheme and the powder coating on the case. Have you decided on colour of coolant yet.
  11. montymole
    24 May 2010
    Yes Mayhems have been kind enough to give me some Pastel Red Big Updates over next 24 hours
  12. montymole
    24 May 2010
    Sorry for the lack of updates been a little busy with so much going on and i was not happy with one or 2 things so made some changes
    New Fittings
    [​IMG][/URL][/IMG]
    Pump installed int to the bottom with the drain tap and the cables part sorted
    [​IMG][/URL][/IMG]
    Revesred the Bay Res as i wanted a cleaner looking front
    [​IMG][/URL][/IMG]
    The New Front Thanks to Nate George :)
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    Again thanks Nate for the supplies
    [​IMG][/URL][/IMG]
    Fixing with Plastic Weld
    [​IMG][/URL][/IMG]
    There is another plate to be cut and a some frosted red plexi for a trim to add to this but here is the front
    [​IMG][/URL][/IMG]
    Thats all for now folks .........
    snef likes this.
  13. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    It's great watching stock vanish from the store and appear in the build :) Glad to have someone with so much passion just around the corner!
  14. gavbon
    gavbon Extreme Overclocker/PC Anarchist
    6 Feb 2013
    Absolutely gorgeous
    You have my support bud!
  15. montymole
    24 May 2010
    Thanks Nate and Gav :)
  16. snef
    18 May 2014
    want more, MORRRRRRE,
    simply amazing, subbed
    will follow this build logs
  17. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    ooo i like the way the res faces inside the case, neat idea!
    Cant wait to see updates!
  18. montymole
    24 May 2010
    The Plextor M6e Pcie SSD was little green looking for this PC so out cam the Plasti dip
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
  19. montymole
    24 May 2010
    A look inside
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
  20. montymole
    24 May 2010
    Loop Filled and new front installed
