Quick question. Basically my PC is getting pretty bogged up with crap I don't use or have forgotten about. Very little is actually precious information (any pictures and videos etc are backed up on an external drive and the cloud). I want to reset Windows 10 from scratch, no information. I have an SSD with the OS and a 2TB drive for mass storage. If I use Win10's 'reset this pc' option, will it clear out everything and will I expect any caveats with this?
I'm guessing this is similar to SysPrep? There are others on here who use SysPrep quite frequently - hoping that someone like Shirty will chime in
I don't think I worded it properly. Basically I wanted to clean install. Is this achievable within windows, using a process that isn't completely convoluted?
Yep, it does a clean install. You keep your files, drivers and updates, but everything else is removed.
