Memory Quad channel kit in Z77 board.
Discussion in 'Hardware' started by Thatguy119, 5 Jun 2012.
  1. Thatguy119
    Thatguy119 Minimodder
    17 Nov 2008
  2. feathers
    feathers Minimodder
    11 Apr 2009
  3. Thatguy119
    17 Nov 2008
    Cool beans, so I can overclock it as well. Even if not it still seems like better value.
  4. feathers
    feathers Minimodder
    11 Apr 2009
    In a review on tweaktown I think, the 1866 was overclocked some distance beyond 1866. I haven't tried OCing mine.
  5. Bede
    Bede Minimodder
    30 Sep 2007
    OC'ing RAM for current-gen Intel boards will make no difference outside of benchmarks. The same can be said of the difference between 1600MHz and 1866MHz, but if they're the same price then you might as well go for it.
  6. feathers
    feathers Minimodder
    11 Apr 2009
    That's why I don't bother OCing it. Even if I had 1600mhz I wouldn't bother.
  7. casann
    casann What's a Dremel?
    8 Sep 2011
    All the dual/quad labelling basically means is that the sticks will work together without issue. So if you have a quad channel board and bought two different dual channel kits, there's a chance they won't work together as there might be certain differences.
    Teelzebub and Shirty like this.
  8. Shirty
    18 Apr 1982
    Now then, is that you Casann or has Noiz accidentally posted using your login?
    If it's the former then kudos for getting involved in hardware. :thumb:
  9. casann
    8 Sep 2011
    Me ! Got told of for not posting anywhere else so thought i would lol
