Scratch Build – In Progress [Casecon] Light Glass [Worklog]
Discussion in 'Project Logs' started by ronny78, 24 Aug 2015.
  1. ronny78
    ronny78 Minimodder
    13 Aug 2015
    "Light Glass"
    All final pictures
    Welcome to my next project " Light Glass " .
    As the name suggests, I will in this project an ATX Acrylic Case construct in which a lot of acrylic glass and some aluminum is used.
    Here is a little taste of what I had before .
    Is perhaps not very impressive but better than on a piece of paper and when you see what I have done from my last project , I am hopeful . :)
    These are the very first 3D models I've ever made ​​.
    The Concept:
    My concept is as much transparency in connection with frosted acrylic glass front . Some contrasts are decorated in white and minimal black .
    There are transparent acrylic tubes 16/12 are fitted with white coolant .
    The transparent housing should be kept as small as possible and just cover the hardware .
    In the base should still find a 360mm radiator square next to the power supply and a DVD / Blueray drive.
    The Hardware:
    Mainboard: MSI Z170 Titanium Edition
    CPU: Intel Core I7 6700K
    Ram: Avexir Raiden 4 x 4 Gb 2400Mhz
    Grafikkarte: 2 x MSI GTX 970 4GD5T OC
    SSD: Avexir S100 Series
    Power Supply: Cooler Master V 750
    The Water Cooling:
    Pump:
    CPU block: EK-FB MSI Z170A XPOWER TE Monoblock - Nickel
    GPU block: EK-FC970 GTX TFX - Nickel
    Terminal: EK-FC Terminal DUAL Parallel - Plexi
    Reservoirs: EK-RES X3 250 - White
    Radiator: EK-CoolStream PE 360
    acrylic tubes: EK-HD PETG Tube 12/16mm
    acrylic tubes fittings: EK-HDC Fitting 16mm G1/4 - White
    fans: 3 x Silencio FP 120 PWM
    Winkel: CoolForce 90° drehbarer Anschluss Adapter G1/4
    equipment:
    Keyboard: Cooler Master Quick Fire XTi
    Mouse: Cooler Master Reaper
    Mousepad: Cooler Master Swift-RX L
    Headset: Cooler Master Sirus 5.1
    Fan: Thermaltake Riing White
    Stepper Motor 28BYJ-48
    Driver ULN2003
    Ultrasonic sensor HC SR04
    90db buzzer
    keypad
    Arduino Nano
    infrared receiver
    capacitor 1000 microfarad
    Wiederstaand 470 Ohm
    div. Pins Connectors
    Digital RGB LED Strip WS2812B
    remote
    RGBW LEDs
    So much for my basic idea .
    The planning and preparation has been underway for several weeks , the details will follow shortly !
    I hope you like the idea and you supported me wherever they can.
    Sponsored by
  2. ronny78
    ronny78 Minimodder
    13 Aug 2015
    So then let's go .
    Bending former No.1:
    Since I am quite at the point at the beginning of my project and do not know how much more will happen to me , is the motto SAVE !
    Needed angle and something round , what I found ?
    Leftovers from my Dreamy Water Framework and an old leg a bar.
    From this could be determined to do something , I thought.
    So I first halved to 2 angle trim the square of the length .
    And the table leg tailored to length .
    Now everything interconnected , clean at right angles , of course
    That looked so far quite good , because I was working on an actual bending device ( which we refer later ) , I have ever tried the simple method .
    The object to be bent is clamped at the other end a few clamps and stretched HEATER with the heat gun , then exercise gravity .
    Has so far also worked quite well , but the result was more than unsatisfactory .
    Even though I ( was the test object can also totally wrong clamped ) at the point with more patience and better technology could achieve a more beautiful result ,
    but was aware that the radius absolutely not my needs are met . So brainstorm was only times announced.
    At the point I can also help me of you . ;) :p
    Since one always get your best ideas while working there went with the
    bender No.1 on.
    The I had ever seen in Ali and I thought this must be but can extend over a larger area .
    So my first issues .
    Ab bought the hardware store , wood and angle at Ebay a reconditions Wire , Kanthal wire , constantan wire or guitar strings . All usable , I bought the first two .
    Now two boards with angles associated with so much distance that suits the wire in between.
    The angle completely wrong mounted from below rather than from above and off-center but right-aligned . I had unfortunately found only after weeks toturial in English .
    That's why I was able to try out my new router at the point times , the last was at Aldi offer .
    The limited hours is often come to use .
    Someone said : Those who buy cheap buy 2 times !!
    I say Who buys expensive , not builds . Because he has no more money !! :D
    from underneath
    even a stop at an angle mounted ( also wrong again , which is slightly rounded bottom as can thin plates slip purely and due to temperature difference is the choice of material also not optimal , I have him replaced by wood )
    On the surface I have glued aluminum foil with spray adhesive .
    And I just could not find the correct power supply I had simply times tough connect the wire to 220V here . : pillepalle :
    Were NEN mighty bang everything was bright and so it looked then from : : lol : Do not TRY THIS !!!!
    Well, after I had corrected all errors , instead of aluminum foil I have folded a steel plate and bonded with Sikaflex , seen the whole like this:
    Since the correct power supply had only ordered because you get a PC power supply only a maximum of 40cm to glow I made here my first attempts ( no hair dryer ) .
    The PSU has the way the bucket during this experiment . ? (
    because I could not heat up long enough for the defective power supply , it with double-sided heating (in addition with hairdryer ) also works much better and I have the temperature difference to the bending form is not observed, these results were not satisfactory .
    It should be noted : The Kanthal must 'll tensioned with a spring over the entire length in order to keep the tension .
    As the leading power at the ends of a slotted screw very well because on the one hand align the position and the height can be adjusted other .
    Well as you could see in the background already, the development phase was nearing completion and I was able to start the Beta phase.
    The bending device NR.2 (the edges of acrylic glass)
    Following the example of my first attempts I could see the small bender create no problem.
    Since I have the plexiglass plate is always heated on one side only at the beginning I was able to create a clean edge but on the edges there were small cracks despite adequate temperature.
    Heating by both sides, in addition to a hot-air hair dryer / blower, I was able to increase the quality still is many times
    rounding right
    the same on the bottom right
    Here are the AC Power Adapter that I've bought for about 20 Euro at EBay. 24V 15A
    and although there was nothing in the description can be there even rules of 18-28V
    So now it was only create The final shape for the side part.
    Housing depth is about 24cm which should be just under 5cm deducted for the cables behind the motherboard (incl. Wall thicknesses) remain 19cm.
    So I decided for a radius of 16cm! :whistling:
    Even if I wanted to press yes to the work, did not help, it had to be a professional form.
    Again from the hardware store, be advised that some wood quite well can be forms, I know it not still but something they have sold me, and it has also worked quite well.
    So 8 boards only times the radius penciled:
    Then it was time to cut
    all ground still plan
    now milled recess for bracing
    and glued together
    yes I know I need a lot more and much bigger clamps
    Now here again applied the glue and glued to be bent shape
    I thought it breaks through, because it was really stiff, but worked fine :rolleyes:
    So, apart from a few bending tests my preparatory phase has been completed and I'll probably order tomorrow the material. :thumbsup: ​
  3. InsolentGnome
    InsolentGnome Minimodder
    14 Apr 2015
    On my acrylic case, I did your first bending method(around a piece of pipe), but just started with a little larger piece than I needed, bent it, and cut the warped edges off when I was done. It was the simplest method for me.
  4. Cheapskate
    13 May 2007
    To get a good straight bend, I used a mold like that, but I used a big sheet of metal that I could clamp down over the top.
    I had to throw it in the oven a few times to get it completely folded too.
  5. ronny78
    ronny78 Minimodder
    13 Aug 2015
    @insolentgnome
    Thanks to you, I think I'll do the same
    @cheapskate
    an oven I would also have preferred, but unfortunately it does not fit purely.:-(
    Sorry for my english, i hope i understand it correct.
  6. ronny78
    ronny78 Minimodder
    13 Aug 2015
    So on we go :
    The required Material has finally arrived .
    The acrylic glass for foundation
    The acrylic glass for the showcase
    and the aluminum profiles for the foundation
    So then , I immediately to the skeleton for the Base made.
    All parts cut to size , filed a length and deburred .
    Then all the parts were connected together , cut with thread M3.
    The protruding screws will I later cut all and probably glue with liquid metal.
    So you can even make you a better picture of the size , here's a comparison to my Cooler Master Cosmos 1000 !
    Clear a Midi Tower I need not put beside it, which would be just as large as the base . :)
    Next, I am Polishing practiced me something and the cube made ​​with the I'll screw the acrylic sheets in the visible range with each other .
    Since I have cut to size of the cover , an industrial expansion tank , 3cm cubes .
    With the blow torch to it has been seen in the photo , I've tried me once in flame polishing , but that did not work .
    The has no constant power .
    First I have the sawn edges sanded by machine dry with 180 and 240 paper
    and then worked my way up to 320 , 400 and 600 wet sandpaper .
    Normally, one should not go to the 2000 paper but that I had not and the result is sufficient for this purpose .
    Then I worked on all surfaces until the blue and then the red polishing paste with a polishing felt .
    Not to conclude with a car polish and a cotton top .
    Left to right
    I love the result , for my first attempts not so bad .
    Should 3cm cubes later look too chunky I will this reduce to 2cm .
    So it was time again for the time being .
  7. timpelay
    timpelay What's a Dremel?
    18 Jun 2015
    I admire you commitment. Keep on working! :)
  8. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Thanks to you , I'll give my best!
  9. ronny78
    ronny78 Minimodder
    13 Aug 2015
    As you might have already noticed, I was invited to the Game City in Wien with my project "Dreamy Water", why I in this Con does not really get on because we are working on the details for the dwarf since several weeks.
    A little bit I've done yet. :p
    SSD Tray
    Really good pictures I have not done since I again seemed to me a little clumsy . 8)
    So here I have made myself familiar with the first direction of the router,found the whole mass, how far the stop must be removed from the router etc.
    milled first time with a V - groove cutter , the depth of the tray.
    Then we continued with a chamfer cutter
    looked pretty out unevenly,until I had it only once halfway again sanded smooth
    Now I've worked my way again with180er,240er,320er,400er to 600er sandpaper high.
    There is still no master fell from the sky! ;)
    I like it but better than expected.
    On the back I'm still a little hollow mill to integrate a LED stripe there.​
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking good & nice progress. :)
  11. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Nice to hear, thank you.
  12. Cheapskate
    13 May 2007
    Rock hammer: :thumb:
    BIG plastic: :rock:
    I love what you built so far.:D
    If you have a wet saw/tile saw, they are great for cutting thick plexiglas.
  13. ronny78
    ronny78 Minimodder
    13 Aug 2015
    :rock::D
    No I have not , unfortunately , not yet.:hehe:
    but the table saw works quite well.:rolleyes:
  14. ronny78
    ronny78 Minimodder
    13 Aug 2015
    In addition to my preparations for the Game City has also done a little in this project .
    I have received a Packet:
    Thanks hereby
    for the great support.
    There were definitely some nice stuff in there
    3 x Silencio FP 120 PWM to cool the 360s radiator in the base.
    Then the Swift-RX Lmouse pad.
    Next, you can still see the Reaper mouse.
    very cool packaging
    White LED lighting fits perfectly to my concept .
    I believe I will change a few things .
    The lighting in the front acts like a flashlight in the dark . :D
    then the Sirus 5.1 Heatset.
    The previous best wearing comfort which I had by all Heat Sets.
    That says a glasses with big ears
    (comparison to G35, medusa NX,Creative WOW,steelseries 7H)
    last but not least the Cooler Master V 750
  15. ronny78
    ronny78 Minimodder
    13 Aug 2015
    And on we go....
    Now that I have the power supply , I could obstruct the same , but I just had to put an additional angle
    Then I realized my idea of a new Reservoir Holder, In addition I have cut off a 80 / 70mm tube obliquely
    cut and a slightly oblique hole, everything sanded flat and smooth
    The oblique neck was not very symmetrical,I have already revised,
    but I am not yet come to grind because I lack even an acrylic rod of the I will build the holder.
    The entire tube gets then from 3 sides a 5mm threaded around the reservoir to fix with screws.
    Because I want to anyway have a slightly riveted look outside,(So all 5-10cm black screws) all exterior parts interconnect,
    I had to tinker still a few angles for (the polished cubes are only for securing the curved lid).
    So I could not take my bender equal test times again and broaden my experience with acrylic glass. ;)
    The front I additionally heated by the hot air blower to provide feed for uniform temperature.
    The result was quite good until here, I would have just left the tempering, since all angles have fully cleared so I could do it all again.
    The angle measure I have subsequently sawed cope
    ground and deburred all edges
    works better than by hand with this grinding holder so I could avoid to round the edge.
    since the ends have but bent a little high, I will shorten this yet
    Finally, as I understood now everything had gathered around me to build a sliding door, I was able to assemble the track yet.
    For that I had to put something back to the top corner from the base frame
  16. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Nice Project.
    And a good plexiglas course.
    Thanks... ronny 78
  17. ronny78
    ronny78 Minimodder
    13 Aug 2015
    thanks, let's see what I'm doing it. ;)
  18. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Here we go finally on.
    The first parts for the water cooling arrived.
    is so kind to support my project. Thank you.
    First, the EK-HDC Fitting 16mm G1/4 - White and the EK-AF Pass-Through G1/4 - Black
    Then the brand new EK-RES X3 250 - White
    and the EK-FB MSI Z170A XPOWER TE Monoblock - Nickel
    which then also clear that motherboard comes in this mod for use. ;)
    Next, the window which I received a while ago.
    Thus, a heartfelt thanks to firm
    for the discount and support.
    Before I continue working on the case right, I'm going to color-customize your mouse, keyboard and headset for the concept.
    These are as quick as possible Updates! ​
  19. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Peripheries
    First a huge thanks to
    for the discount that allows me the beautiful mod.
    Also a thank you to
    for the provision of peripheries.
    First, the Quickfire XTI keyboard.
    After some fumbling I got the keyboard but then dismantled get without damaging them.
    This I then taped.
    After I cleaned it was primed with a special plastic primer and then painted 2 times with champagne pearl plus 2 layers of clear coat
    The Reaper mouse I could completely disassemble all parts and paint just like the XTI.
    Now the headset Sirus 5.1.
    Here absolutely nothing worked.
    Firstly, many parts of the housing are plugged in and clipped these were then but back melted to leave to make way for other parts.
    Thus I could not disassemble optimally to work clean the headset.
    On the other hand went here with my coat absolutely nothing.
    Unfortunately, it is not the color which dissolves there but the plastic itself, with every clean the surface it will only get worse.
    I have it sanded best and just hammer out by many smaller operations.
    A masterpiece, this is not, I know absolutely not what I can do there yet, since all other paints to make any liability to the plastic.
    The earcups I dyed with leather color, this process I had to repeat almost 10 times until the result was fairly satisfactory.
    The head pad I covered with my white leather
    Done, so here are the results.
    The XTI got a completely white Keycapset, a silver set of internal keys, Silver Arrow and Caseking ESC key.
    On Case I have to continue working, more accurate about this soon! ;)
  20. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    WOW! Excellent work Ronny!!
