News Asrock unveils Z170M-PIO2 uDTX motherboard
Discussion in 'Article Discussion' started by Gareth Halfacree, 4 Oct 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    I love how Asrock actually like to innovate in the motherboard space, much like with their X99 ITX board.
    This looks to me like a seriously interesting option for ITX as it fits with the principles of many existing case, although at the cost of not actually being supported by them. If Asus and Gigabyte hop on this train I can totally see a new trend of thin ITX cases based around the concept. Switching around the orientation is rather cool, means the cards are actually facing the right way too.
  3. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Now do the same with the ATX power connector and we're laughing.
    EDIT: I re-read that and it sounded a bit negative, so thought I'd add that I also respect ASRock and their way of thinking :)
  4. Combatus
    16 Feb 2009
    +1
  5. Guest-16
    Guest-16 Guest
    +2
  6. Fizzl
    Fizzl What's a Dremel?
    9 Jun 2009
    This is a nice idea but let's take it further.
    Drop every IO other than a good selection of USB and Ethernet.
    Loose the sata.
    Hide a few m.2s about the place.
    Come up with something better than an a 24pin ATX.
  7. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I like the look of this. What is there in the way of compatible low-profile cases out there? As the article says, I'd love to see a super-slim VESA-mountable case so I could hide this behind my monitor, but I'd imagine that you'd need an external PSU to make it work.
  8. Goatee
    Goatee Multimodder
    19 Apr 2015
    I would have liked to see the CPU power socket next to the main ATX socket rather than in the middle of the board. Same with the USB3 socket.
    Both of those would make cable layout much easier.
  9. Gareth Halfacree
    4 Dec 2007
    The PIO chassis standard is designed around having the motherboard and other components built into the monitor casing (it stands for Parts In One). There are some on the market, but I'm not aware of any uDTX-compatible ultra-slim desktop chassis compatible with PIO-targeted motherboards yet. At least, I haven't been able to find any.
  10. Guest-16
    Guest-16 Guest
    Kickstarter opportunity for a nice case imo.
  11. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    How is this different from a motherboard with a 90 degree PCIe riser in a 1u rackmount case? I mean, sure the layout of the components is different, but I'm failing to see how this is really so groundbreaking. :confused:
  12. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Oh yeah, for real. Would love something like this that I could hide behind my screen, free up a ton of desk real estate and still have a full-power SFF PC.
  13. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    The rub is that while there are plenty of PIO boards from various vendors, none are available for consumers to purchase directly. Instead of kickstarting a case (which for a very small run already compared to even the few ITX Kickstarters like the Ncase M1 and Dan A4, would not be cheap) you would need to Kickstart a 'barebones' machine, which is s tougher prospect for the target market, who likely would want the flexibility to choose their own components, and to upgrade the motherboard at some point.
