Scratch Build – In Progress Project : Sors salutis -by AnG3L(15 April 2011 - Video is UP)
Discussion in 'Project Logs' started by AnG3L, 10 Dec 2010.
  1. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Scratch build : Project : Sors Salutis
    Intro:
    Hello there my friends again, I am back for our fourth journey through the magic world of modding!
    I named this project inspired by Carl's Orff famous song Carmina Burana.
    Sors Salutis means fade is against me.
    The project will be as you already realised a scratch build mainly composed by acrylic and wood.
    The colours will be white, black (wood) and red.
    2 different compartments will host:
    no 1 - motherboard, psu, hdd, dvd-rom, reservoir and
    no 2 - radiators, pump
    These 2 compartments will be removable for easier transfer.
    After countless hand drawings and different concepts I came up with this final design
    which you will see unfolding through my updates day after day as I will work as fast as I can
    to finish this project as soon as possible.
    I tried to stay out of the normal "box" style case and hopefully you will all like it at the end!
    Enough with this little intro, let the journey begin!!! :)
    SPONSORS:
  2. AnG3L
    19 Mar 2009
    So to give you a clue how the build will look like here is the front (many things will be added though etc)
    And here is the back side:
    These are some of the acrylic main pieces I am going to use:
    More of them! The clear acrylic will be used for illuminating by red leds.
    So lets begin with the modding! I will use different kind of wood as you will see.
    For the clear acrylic covers I am going to use a 3 mm marine plywood.
    Here I draw the covers on the wood to be cut later on.
    For my previous experience this particular piece of wood cannot be cut with a jigsaw as its very thin and it chips off very easily
    but I am going to use it to make the big cuts and then find a way to do the details.
    First I used this blade which it was a fails so I changed it with a blade I use for metal.
    First piece removed!
    Second phase!
    The only way for me to cut the wood with damaging it, it was the dremmel! Time wasting process and a lot of burning wood smell lol !!
    By using a bit for carving wood I did the round parts which I first drilled.
    Then it was time for the sanding drum to come in action.
    For the final touch I attached the acrylic part with the wood to file it and make them fit together perfectly.
    Here are the (almost) final shots for the covers.
    So thats all for now guys, I will try to work as fast and give you updates as soon as I can. For the moment it rains so I will stay inside
    but soon as the weather is shiny again I will be back!
    Thanks for reading guys and wish me good luck for this 4th journey!! Peace!
    Razer2007 likes this.
  3. AnG3L
    19 Mar 2009
    I forgot to mention the hardware! :p
    So in this mod I am going to use the components I used with Case Mod Project : AnG3L.
    Evga X58 F T W motherboard
    Intel Core i7 920 @ 4Ghz
    Corsair 6gbs ram @ 1866 Mhz
    Asus GTX 295
    all watercooled
    hdd and dvd will follow soon as I might do some hardware changes too.
  4. DeadP1xels
    30 Nov 2009
    *Pulls up seat and begins to listen*
  5. AnG3L
    19 Mar 2009
    ;) Thanks bro, welcome to this journey! :)
  6. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    You are a profilic Modder, if only I had the time to mod as much as you! Between college and work, I just have no time, though, maybe this spring I will build something. Anyways, the build looks to be awesome!
  7. AnG3L
    19 Mar 2009
    Thanks buddy, well I used to work before too but after a serious accident I couldnt work fulltime anymore so now I have the time to mod as much as I want or perhaps as much as my spine allows me to!
  8. stonedsurd
    11 Mar 2009
    NO! NO! NO!
    You cannot keep doing this! It's not fair to the rest of us :hehe:
  9. AnG3L
    19 Mar 2009
    LoL ;) Well at least I have one passion besides smoking to feed my earthy life! ;) Thanks bro! Welcome 2!
  10. ringoiom
    ringoiom What's a Dremel?
    20 Jul 2010
    Sub'd - loved Future Schlock - Glad I can be in on this one from the start!
  11. The boy 4rm oz
    10 Apr 2008
    This is looking to be another very cool project Alex. I can't wait to see how it turns out :D.
  12. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    Yeeehaa, you just made my day.
  13. Alexandros
    Alexandros What's a Dremel?
    10 Jan 2010
    Oh no you didn't. Just when I got rid of that nasty addiction, you release another build!
    Glad to see you start another one though :). I can't wait to see how it turns out.
  14. AnG3L
    19 Mar 2009
    Thank you my friend, welcome 2 to this journey!
    Thanks Jason my friend I hope you wont wait too long as I will rush this project!!! :)
    You made my day too buddy!!!! :)
    Nasai kala file mou, thanks for the kind comment!!! :thumb:
  15. stonedsurd
    11 Mar 2009
    Smokin' aint a passion bro. Given that I'm usually surrounded by a haze of smoke, I'm the last person to get preachy but I'm sick of hearing about people I love and care about dying from smoking-related causes, so I've decided to get out while I'm ahead.
    Anyway, I'm not going to fill this log with lecturing and BS, so mod on and let's have some more jaw-dropping stuff that only you can deliver!
  16. Attila
    Attila still thinking....
    22 Feb 2008
    That was quick! :eeek:
    Good to see you back at it, I'll be watching as I'm sure it will be as interesting as your other work.
    Good luck. :thumb:
  17. dralix
    dralix What's a Dremel?
    2 Dec 2010
    nice shapes, good luck with your build!
  18. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    I've read all of your project logs and there is only one way to say this but your work is astounding! Im glad im here to see this one from the beginning, mod on and let the brilliance continue!
    oh and ps. sub'd!
  19. AnG3L
    19 Mar 2009
    I will on smoking and modding then!!! Thanks bro!!
    Brother, my honor to have you here again next to me and my work! I hope you will like it! :D
    Thanks for the wishes my friend!!! :)
    Thank you very much my friend for appreciating my work so far and for taking the time to read through all my projects!! Welcome to the 4th journey! :rock:
  20. Razarach
    Razarach Minimodder
    28 Jan 2009
    :brrr: nice work so far, this will be awesome build.
