Networks Cisco 3560-24ps-s POE to cameras
Discussion in 'Hardware' started by tytech, 26 Jun 2015.
  1. tytech
    tytech What's a Dremel?
    25 Jun 2015
    Is it as simple as that?
    Can I just connect the cameras into the switch being that it says POE and it will power and work??
    :wallbash:
  2. adam_bagpuss
    24 Apr 2009
    yes as long as you dont exceed the maximum output of the cisco switch over POE
    there is a standard but diffrent units can output different amounts and may not be able to service all 24 ports at full load
  3. law99
    law99 Custom User Title
    24 Sep 2009
    Yes and no. There are different PoE standards. Most PoE products work on the 15w that you get from PoE. Some require higher amounts. This is where people get caught out. The 802.3af vs 802.3at. Most products seem to work on both, but occasionally you get a burn or two.
  4. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    The only PoE cameras that would require 802.3at are ones with really beefy built in heaters or PTZ on large cameras. Check the specs on your camera to be sure.
    With regards to the 3560 itself - you can use it as a dumb switch with full PoE support, but I'd still at the very least put a console + enable secret password on it.
