Modding Acrylic Showoff - All different colors, surfaces etc
Discussion in 'Modding' started by Fonne, 9 Jun 2012.
  1. Fonne
    Fonne What's a Dremel?
    9 Oct 2010
    Hi
    Working daily with acrylic and plastic, so thought some people would like to see that acrylic is not only a transparent material ...
    Is this something people would like to see more off, or should i just stop posting now ?
    Regards Henrik
    Loafers likes this.
  2. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    do you take comissions inside danemark? :3
  3. Fonne
    9 Oct 2010
    Normally no, and dont have the time right know - Also the speciel colors you offen need to buy them in 3x2m = $$$ - But send me a PM ...
    Some sparkle and glitter ...
  4. Fonne
    9 Oct 2010
    Matt finish - Much easier to keep clean ...
  5. barfastic
    barfastic What's a Dremel?
    21 Feb 2011
    im in love.... are you based in the US or EU?
  6. Fonne
    9 Oct 2010
    EU ....
  7. barfastic
    21 Feb 2011
    Can you pm me a link of your shop or contact details etc etc?
  8. Fonne
    9 Oct 2010
    The company that I work for, is 100% subcontractor, so we buy from that larger acrylic distributors around EU
    Really hard to capture the sparkle right - Hope you like it, not the acrylic you see every day
  9. bluc
    bluc What's a Dremel?
    4 Apr 2012
    You have any shots of two way mirror? Also wondering how much light behind mirror is required to make it transparent?
  10. longweight
    7 May 2011
    2 way mirrors have a 50% mirror coating on one side so you need quite a lot of light on both sides to make it work.
    You also need to have very controlled natural lighting in the space to make it work.
  11. bluc
    4 Apr 2012
    I was thinking of a pc case so during day its mirrored and at night in dark its see through but I am pretty sure it would not be clear enough to easily view parts although the lighting I am getting is pretty bright and there will be lots of it will be using about 12meters of 5050 led strips:D
  12. longweight
    7 May 2011
    During the day it will be mirrored if the internal lights are off.
  13. Cheapskate
    13 May 2007
    EU plexi teasing.:(
  14. Unicorn
    25 Jul 2006
    Who thought that Acrylic was only transparent? :confused:
  15. Fonne
    9 Oct 2010
    Most people just uses normally transparent, and dont have access to this kind of colors, or maybe dont know that you can get glitter acrylic etc ....
    Just wanted to show people how big a variation of acrylic you can get - And there is many more.
  16. Unicorn
    25 Jul 2006
    I'd say I use about 50% more opaque coloured Acrylic than transparent or translucent, but that's just me :thumb: You have a very nice selection - I'll shoot you a PM when I get back home to my own PC about some colours... I might be needing some more in the next little while :)
  17. kelvinb
    kelvinb BF3 Username - D0rmarth
    20 Sep 2011
    Now you showed us what we can get all you need to do is show us how to get them ....
  18. DarthBeavis
    DarthBeavis What's a Dremel?
    29 Aug 2008
    I hate acrylic would NEVER work the stuff never touched it never will
  19. Pranja
    Pranja Blackwolf
    18 Dec 2011
    I only thounght there was transparent and non-transparent in all colours, but never saw saprkle and matte transparent,or glass one.
  20. Unicorn
    25 Jul 2006
    Why?! :confused:
