Storage M.2 SSDs
Discussion in 'Hardware' started by Jumeira_Johnny, 2 Mar 2015.
  1. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    Is anyone using an M.2 drive that could give an insight into how the standard is shaping up?
  2. faugusztin
    11 Aug 2008
    M.2 is complicated, and simple :)
    SM951 , XP941 and Plextor M6e are the only PCI-E based M.2 drives (in order of speeds from best to worst). Everything else on market are SATA drives.
  3. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    Not currently using one, but when skylake hits the shops, I'll be buying. The most important bit is how many PCIe lanes and what revision they are; 2x 2.0 is a bit lackluster, but 4x 2.0/3.0/4.0(skylake) all hold the promise of multi GB/s transfer rates, numbers that just 15 years ago would have been considered outstanding for RAM, nevermind a disk subsystem.
  4. stealth80
    stealth80 Minimodder
    1 Feb 2015
    Im using a Samsung XP941 and i can throw you a little insight on my experience with it:
    I bought it to use with the Asus Ranger Z97 board which is M.2 compatible having read some great reviews about the drive. I had originally planned to use the new 850 evo, but i quickly moved that to the wifes build :worried:
    It came and to physically fit it was very straight forward, installing it however wasn't quite so simple. The drive has to be installed in UEFI mode and requires the newer windows variants for this to be possible (not sure if W7 is support please correct if I'm wrong :D). Initially everything went according to plan as per a new windows install until after the first reboot, it just wouldn't recognise the os and nor could I get it to recognise the drive again. Once I googled M.2 installation from my laptop i found a few guides and then realised about the UEFI. Once this was corrected and i made all the various bios changes everything went well.
    Once it was all installed it felt pretty quick coming from an OCZ Agility 3 and I decided to run a Hard drive speed test to see how fast it was in comparison to the review item. Here i came across my second over sight, the review drive was hitting 1080 mb/s read/write (approx) where as mine seemed to be capped at around 870 mb/s, not slow at all but i felt a little short changed. It was then i found about the Z97 m.2 limitations ...
    Basically the m.2 is limited to 2x PCIE lanes which causes a bandwidth cap on the drive. I believe there are now a few z97 boards available (Asrock Z97 Extreme 6) which support full 4x PCIE lanes on the M.2 adapter and i'm pretty sure all X99 boards have full support.
    This is issue was quickly addressed by buying a PCIE M.2 adapter which gave me full 1080mb/s speeds :clap:
    This is the adapter:
    http://www.scan.co.uk/products/lyco...m)-to-pcie-x4-host-adapter-board-pc-mac-linux
  5. Jumeira_Johnny
    13 Nov 2004
    Thanks. This is for an X99 build, but I'm seeing most drives are still SATAIII and not native PCIe.
  6. silk186
    silk186 Derp
    1 Dec 2014
    thanks for sharing your story and I'm glad it worked out for you in the end. Seems that M.2 will be ready for mainstream with Skylake.
  7. stealth80
    1 Feb 2015
    Basically its shaping up real nice, but if it were me with a X99 system is either go XP951 (if you can find one) or wait until all the players are involved which should shake the prices up a little :)
  8. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
  9. faugusztin
    11 Aug 2008
  10. BennieboyUK
    24 Nov 2010
    Sorry yeah I meant when it was back in stock!
  11. Pete J
    Pete J Employed scum
    28 Sep 2009
    Using a Plextor 250GB M.2 in my HTPC. Installation was a doddle - didn't even have to turn on anything in the BIOS!
    Excellent so far - fastest boot times I've ever seen and (not that I've tested it) supposed to do 700MB/s read/write.
