Motherboards Not reading all my ram
Discussion in 'Hardware' started by Kovoet, 1 Feb 2010.
  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I have a ASUS P6TD Deluxe. Got to be careful with this board as it doesn't read all the ram, then If you have already installed OS and all modules are of the same Spec, Then go with installing 3x2gb first. into banks A1,B1,C1 then startup into Bios and enter ram settings manually (timings & Voltage & ram speed)), save and boot into windows check and see if all of the 6GB is available to windows. If so the shut down and PWR OFF and place second set (3x2gb) into bank A2,B2,C2. Again boot into windows and check to see if all the ram is available to windows.
  2. Kovoet
    26 Aug 2009
    I have done an update and it still only reads 2gb in the bios when I actually have 6gb installed Would it be better if I just went back to Windows XP
  3. DeathAwaitsU
    DeathAwaitsU I'm Back :D
    27 Feb 2004
    Which Windows? Vista? 7?
  4. Guest-16
    Guest-16 Guest
    XP is 32-bit so you'll hit the 4GB limit pretty quickly.
  5. Kovoet
    26 Aug 2009
    I'm using Win7 64bit
  6. Guest-16
    Guest-16 Guest
    What are you using to read it?
  7. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    He said BIOS.
  8. Kovoet
    26 Aug 2009
    Bios and going to the control panel, system route
  9. CarlT2001
    CarlT2001 What's a Dremel?
    23 Jul 2004
    Yep - I am having a similar problem with the P6TD Deluxe and Win7 64bit. I got OCZ 1866 gold 3x2gb memory. Sometimes windows sees 4gb sometimes 6gb, but CPUz always reports 6gb installed. I am hoping its just a BIOS issue and keeping my eyes peeled for new versions often.
  10. mrbungle
    20 Sep 2004
    Two things that cause this.
    Ram needs changing or cpu the isnt making great contact with all its pins.
    No bios updates etc will sort it.
  11. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Just to check, does the BIOS fail to recognise the DIMMS as well, or just the OS?
    I know dick about it, really, but I'd guess that
    BIOS cannot see them = bad connections
    Only OS cannot see them = software problem, BIOS update needed or maybe try changing timings and such and see if it makes any difference. I know it shouldn't be able to, but it might.
  12. CarlT2001
    23 Jul 2004
    Yes, with my scenario, I am leaning toward the fact that I may have a dodgy connection somewhere. I have swapped it about which cured the problem for a little while...but returned. Could be memory or DIMM slot..who knows...
    Strange that CPUz can see all 6gb without fail every time though.
  13. Kovoet
    26 Aug 2009
  14. map01ch
    map01ch What's a Dremel?
    3 Feb 2010
    This is to do with the CPU (in case some dimm will not boot), not only ASUS has this issue, Gigabyte and MSI are both having this issue too. Intel has to fix it........ :duh:
  15. Big Elf
    23 Apr 2009
    You might need to increase the QPI voltage especially for RAM running at 1600MHz or over.
  16. Kovoet
    26 Aug 2009
    Changed the voltage and it didn't work. I have tried everything and my screen goes to blank the after a while it changes to a light blue screen.
    Will now try and change my PSU but I tell you what I am sorry I went spent all this damn money and stayed with XP and a 775m socket, yeah I know I am real disheartened by this. The worst thing I took a weeks leave so i could have some fun.
  17. Big Elf
    23 Apr 2009
    What voltage did you use? You may need around 1.45v.
  18. Kovoet
    26 Aug 2009
    I tried from 1.3 to 1.65
  19. Big Elf
    23 Apr 2009
    Have you run MemTest86 to check each stick?
  20. Kovoet
    26 Aug 2009
    Weird as it may seem this has now been sorted. Don't ask me how but I may have another issue.
    Got a HIS5870, I install windows 7 64bit and no problems except when I install the driver for the gfx card the PC boots and everything except when entering the windows it goes blank.
    I then put in my sons x1950xt and it installed no probs and ran ok in the OS.
    I then tried the 5870 again but to not avail.
