Scratch Build – In Progress (COMPLETED)Project Man of Steel --Sponsored--
Discussion in 'Project Logs' started by MegaSkot, 13 Feb 2015.
  1. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    Hello everyone, my first time here .
    Here are some basic ideas:
    1. home made huge external radiator - wall panel type
    2. custom built case made of stainless steel and plexiglass in shape of Superman logo (yellow and red liquid will go through the "S" logo)
    MB: Asrock Fatal1ty X99M Killer - sponsor Asrock
    CPU: Intel i7 5820K
    VGA: Inno3D GTX 970 OC SLI
    RAM: AVEXIR AVD4U24001604G-4CIR Core Series 16GB Kit (4GB x 4) - sponsor Avexir
    SSD: Transcend 2x256Gb - sponsor Transcend
    PSU: Cooler Master V1000
    Fans: Eight pieces Raijintek Aeolus α - sponsor Raijintek
    All water cooling sponsored by: EK Water Blocks
  2. Shirty
    18 Apr 1982
    Moved to planning until we see some progress. Looks fun though, good luck with the build. Give a mod a shout once you've started your log.
  3. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    Ok, here we go...working on radiator:
  4. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    Home made fittings for radiator case.
  5. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    Stainless steel switches with LEDs have been engraved.
    Thermostats with relay for fans in radiator, 12V.
    Frame for radiator: aluminum square tube 20x20x2mm.
    Frame dimensions are 115x75x15cm, aluminium is connected by welding.
    Position of the radiator is up to the right , to make room for two D5 pumps and reservoirs.
  6. Impatience
    Impatience Minimodder
    6 Apr 2014
    :jawdrop: Are.. Are you building your own rad?! Looks awesome!
  7. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    Yes. :)
    Thanks.
  8. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    Thanks to Transcend, first SSD here: Transcend 370, 256Gb.
  9. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    BIG THANKS to EK Water Blocks for sponsorship :clap:
    1. EK-Supremacy EVO – Nickel
    2. EK-FC970 GTX - Nickel – 2 pieces
    3. EK-HDC Fitting 16mm G1/4 - Blue – 45 pieces
    4. EK-FC970 GTX Backplate - Nickel – 2 pieces
    5. EK-MOSFET MSI X99 MPower - Nickel - 2 pieces
    6. EK-XTOP D5 PWM - Plexi (incl. pump) - 2 pieces
    7. EK-Ekoolant Pastel YELLOW (concentrate 250mL) – 3 pieces
    8. EK-Ekoolant Pastel RED (concentrate 250mL) – 3 pieces
    9. EK-SB ASUS M6G - Acetal+Nickel
  10. Zsolt Guriga
    Zsolt Guriga What's a Dremel?
    20 May 2012
    Thats work man:thumb:,cant wait to see finished:)
    Btw congrats for the sponsors:thumb:
  11. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    Stainless steel 1mm case panels, after laser cutting.
  12. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    Fortress of solitude crystals. I need to polish them...
  13. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    My right hand is dead... :D
  14. Stallion
    Stallion What's a Dremel?
    30 Jul 2014
    Looking good cant wait to see the liquid flowing thru the "S"
  15. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    Thanks. :)
    Now to make green one...
  16. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    Big thanks to Cooler Master Balkan!! :clap:
    :naughty:
  17. Cown
    Cown Minimodder
    25 Feb 2012
    This is looking like it's going to be an awesome build :D
    Off topic noob question, how do you make the frame around all of your Pictures with sponsers and names etc.? :confused:
  18. MegaSkot
    MegaSkot Minimodder
    12 Feb 2015
    Thanks.
    Photoshop: first layer sponsors, second picture.
  19. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Subbed, this looks sweet!
  20. hero1
    hero1 Minimodder
    18 Oct 2013
    This looks awesome.
    Sub dub dub!
