Hardware Asus Maximus V Gene Review
Discussion in 'Article Discussion' started by brumgrunt, 3 May 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. mi1ez
    mi1ez Modder
    11 Jun 2009
    4am review? Damn! Overdoing it a bit Paul?
  3. mi1ez
    mi1ez Modder
    11 Jun 2009
    Would love to see this "River of lava" effect in the dark!
  4. Raccio14
    Raccio14 What's a Dremel?
    28 Dec 2007
    really?. no dark shots, despite talking up how good it looks in the dark?
    c'mon bit-tech.
  5. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    I love the overclocking comment, it just isn't as much fun as it used to be ;(
  6. matee
    matee What's a Dremel?
    12 Feb 2003
    Oh yes we do need the "dark" shots!!
    small mistake: "We were pleased then to see the Gene pull out a little bit of a margin over the reference Asus board and the Gigabyte Z77-UD5H that we tested it alongside in our image editing test."
    Should be "Intel" reference board.
    Anyway thanks for the review.
  7. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    Dark shots on the way.
  8. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    'they’re Goldilocks’ motherboard of choice.'
    :D
  9. SouperAndy
    SouperAndy To Bumble or not to Bumble?
    16 Feb 2009
  10. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    "The board also looks great, especially with its clever backlighting arrangement. "
    Would like to see, please.
  11. wejjy
    wejjy Minimodder
    9 Aug 2010
    Wish Asus would release an ROG itx board, it would sell like hot cakes!
  12. Bede
    Bede Minimodder
    30 Sep 2007
  13. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    Word. That's sexy.
    I'd get on board with Intel releasing a ROG m-ITX series. Toss in a flexi pci-e adapter so the video card doesn't have to be out at 90 degrees and I'll never even look at another brand. I'd like to build a PC where the video card determines the size of the case, over anything else.
  14. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Am I the only one that's a little disappointed by the review? Too much emphasis on aesthetics and not enough technical info in my opinion.
    Where are the power consumption measurements?
    Given the number and positioning of expansion slots available, just how good is the on-board sound? Does it really make a decent sound card unnecessary? (if you go SLI/Crossfire there's really no space for anything else)
    No mention of which Intel NIC is there. This may be a deal-breaker for people intending to play with ESXi. It would have been nice to know if (at the time of writing the review, of course) the on-board LAN is supported by ESXi 5. It's easy enough to test it: just boot from the installation disc, and if it lets you choose where to install it, it works (that is, the NIC is supported). As I said above, sacrificing a slot for an ethernet card so people can test things may prove too much, and a full-ATX board (even with an equally unsupported NIC) is a better option.
  15. Saivert
    Saivert Minimodder
    26 Mar 2005
    ESXi on a ROG board? Really?
    I think there are more practical options out there...
  16. faugusztin
    11 Aug 2008
    82574 is supported directly by ESXI, 82579 is supported through injecting a driver in the installation image :
    http://hardforum.com/showthread.php?t=1607992
    And to be more exact, it is Intel WG82579V according to this czech review, which contains detailed shots of all chips on board.
  17. bOO9000
    bOO9000 What's a Dremel?
    7 Sep 2011
    Can someone please tell me how it's possible to tell which usb 3 ports are intels ?
  18. bOO9000
    7 Sep 2011
    Oh it's ok I just read the manual, intels are the ones next to the lan port.
  19. Cei
    Cei pew pew pew
    22 Mar 2008
    Any more info on exactly how good the onboard sound is?
  20. Ramon Suey
    Ramon Suey What's a Dremel?
    16 Dec 2011
    Asus make a big play of the sound circuitry of this M/B on their website. A little disappointing that Custom PC / Bit-tech review failed to audition the sound. Does it produce a sound quality akin to the Xonar DS or better? If it does it makes this M/B particularly good value.
Tags: Add Tags
