Motherboards Motherboard Bottleneck?
Discussion in 'Hardware' started by dead beat, 25 Oct 2009.
  1. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Hi guys, I'm currently running an AMD Phenom 955 BE and a GTX 295. I was wondering if my ASUS M3N-H HDMI motherboard will be bottlenecking this setup at all?
    Cheers
  2. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    What frequency is your cpu and ram running at? I doubt motherboards can bottleneck an entire system just by themselves.
  3. dead beat
    15 Feb 2009
    My processor is still running at 3.2 ghz (stock). I haven't overclocked it yet. However, I think if there will be a bottleneck, it'll be with my RAM as this appears to be running at only 400mhz.
  4. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Usually the only way a motherboard would bottleneck a system is if
    1.) It has a 4 pin CPU connector and you need 8
    2.) You need more PCIe Lanes than it gives
    3.) There are insufficient I/O connections on the backplate and inside
    4.) The FSB is limiting your CPU overclock
    5.) Your Northbridge has limited features
    to name a few, there are others but I doubt that the motherboard is bottlenecking your system
  5. dead beat
    15 Feb 2009
    I expect I'll be upgrading the motherboard soon anyway. I was looking at the MSI NF750-G55. This board will give me an AM3 socket and will support quad sli should I want to add another gtx 295 at some stage.
  6. Sh0cKeR
    21 Aug 2009
    Problems with Quad sli are : large power draw, large heat production, poor support in games ( most of the time 3 way sli beats out quad ), the dreaded microstuttering. Back to the topic, your cpu should be fine with the 295 but I would definitely sort your ram out as 400MHz is just too slow. As i'm guessing this is a ddr2 board, you'll need either a PC6400 or PC8500 kit.
  7. dead beat
    15 Feb 2009
    Would this OCZ Reaper RAM be compatible with my ASUS M3N-H HDMI DDR2 board?
    http://www.eclipsecomputers.com/product.aspx?code=MEO-D2-4096R9K&af=50
    Cheers.
  8. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    400MHz... DDR2...
    So, could that actually be 800MHz?
    OP, can you get us some screenshots of CPU-Z? They'd help us a bit, with regards to the RAM issue.
    Did they even make 400MHz DDR2?
  9. dead beat
    15 Feb 2009
    Ok here is a screenshot of CPU-Z
    [​IMG][​IMG]
  10. MaverickWill
    26 Apr 2009
    Yeah, your RAM's running at 800MHz. Long story short, DDR2 has 2 pulses per clock cycle - one going up, one going down.
    Its actual speed is 400MHz, but its effective speed is 800MHz (because it does 2 things per clock).
  11. dead beat
    15 Feb 2009
    Ah i see. Well in that case I may aswell wait until I get a DDR3 board before I upgrade my ram.
    Cheers
  12. MaverickWill
    26 Apr 2009
    Are you just planning on sticking to 1 graphics card? If so, the MSI 770-C45 board is about £60 and wins awards left, right, and centre. Couple that with 2 sticks of DDR3, and you could do the whole upgrade for about £100, subject to price fluctuations.
  13. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    umm before you spend any money what are you trying to do that you need to speed up i cant see anything wrong atm is there something specific that is causing you an issue
  14. dead beat
    15 Feb 2009
    I'm just gonna be using a single GTX 295 for now, but i really wanted a board that could support DDR3 and have 2 pci-e lanes so i could quad SLI a pair of 295's later down the road if I wanted to.
