Scratch Build – In Progress The First One build log by Young ModZ
Discussion in 'Project Logs' started by Guest-768813, 22 Mar 2015.
  1. Guest-768813
    Guest-768813 Guest
    Hi modders
    Young ModZ here
    I'm quite new to modding I hope you guys like my scratch build
    This is my first scratch build called The First One.
    Sponsors:
    This is the design:
    components :
    cpu: Intel I5 4690K
    motherboard: Asus ROG Maximus VII ranger
    gpu: Asus Republic of Gamers Mars GTX 760 X2
    ram: Corsair Dominator platinum 8GB 1866MHz
    psu: Bitfenix Fury 750G
    ssd: plextor 128GB M.2 SSD
    Watercooling :
    pump: Alphacool VPP655
    radiator: Alphacool NexXxos UT60 full copper 360mm
    reservoir: Bitspower Water Tank Z multi 250 full clear
    fittings: Alphacool HF screw connector 3/8 ID 1/2 OD
    mosfet and cpu block: Bitspower full cover block
    hdd waterblock: Koolanche HD-40 cooler
    tubing: PrimoChill PrimoFlex Advanced 3/8 ID 1/2 OD
    fluid:
    biocide: Mayhems Biocide Extreme
    killcoil: van mayhems
    base fluid: Mayhems Ultra Pure H20
    dye: Mayhems Dye UV Laser Green
    components pictures:
    update 1:
    i'm at the half of the frame
    update 2:
    before:
    after:
    More updates soon!
  2. Guest-768813
    Guest-768813 Guest
    Update 3:
    i'm done with the frame
    i gotta save up for the plexiglass so the build log is gonna lay still for a few months
  3. Guest-768813
    Guest-768813 Guest
    New Sponsor:
    Update 5:
    Today i got my first sponsor.
    its Cooler master they send me these fans.
    they are:
    4X SickleFlow 120 2000 RPM Green LED
    and
    4X Silencio FP 120 3pin
  4. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Good luck Rowan
  5. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    Not bad. I'm not sure I could have come up with something like this at thirteen. :)
  6. Nexxo
    23 Oct 2001
    Home computers didn't yet exist when I was thirteen. I had a deprived childhood... :waah:
  7. Guest-768813
    Guest-768813 Guest
    thanks guys
  8. Sanjaya
    Sanjaya Minimodder
    4 Sep 2013
    I wish I was this talented when i was 13..... m jel :p
    Good luck bro. and when ever you need help, we are here to help :)
  9. Guest-768813
    Guest-768813 Guest
    update 6
    bitfenix joined as sponsor here are some pics of the stuff i got from them.
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    Where did you learn your metalwork skills?
    Would have been nice to have seen some of the actual work on the frame. But looking really good. Well done, puts anything I have done to shame.
  11. Icelander
    Icelander Minimodder
    3 Mar 2015
    Nice to see such a young talented modder here on bit-tech
  12. Guest-768813
    Guest-768813 Guest
    i will do some pics while i am working next time and thx guys for the support
  13. Guest-768813
    Guest-768813 Guest
    update 7
    worked on the plexiglas some days ago here is the result:
  14. Guest-768813
    Guest-768813 Guest
    Surprise!
    I replaced the R9 290X with an Asus Republic of Gamers Mars GTX 760 X2
  15. Guest-768813
    Guest-768813 Guest
    Last update
    I worked really hard the last 2-3 weeks to finish the build.
    I am very happy with the result and I'm sure to have some fun with it as well.
    Also received some help from my father!
    There was something wrong with the laser cutter so the letters of BitFenix are not perfect. I am going to redo them later.
    Thank you very much : Bitfenix and coolermaster for sponsoring this build! and of course my father for helping! and of course all the support I have received from you!
  16. Shurika
    Shurika Minimodder
    9 Mar 2012
    Hmmm... I see no pics, that's pity!
  17. Guest-768813
    Guest-768813 Guest
    there are alot of pics though :p
  18. Cheapskate
    13 May 2007
    Your pics are cross-linked from Highflow forums. It's obvious they have leeching blocked. You may have to host the pics on BitTech for them to show.
  19. Guest-768813
    Guest-768813 Guest
    but i used the pics from highflow before and they worked but alright ill host them on bitTech
  20. Guest-768813
    Guest-768813 Guest
    can u guys see all the pics again?
