The title says it all, what theme are you useing with winterboard ? I'm getting quite bored of the one I have now and need something new and clean.
Transparent dock, custom background picture.. that's it. Mine's already slow enough as it is and the more Winterboard options are active, the slower it gets from what I've been able to tell.
Themes? Wowsers - didn't know you could do that. TBH, Mine's only JB'd so I can run an SSH tunnel to home in the background for VNC. don't need it to do anything else.
No themes here, just a few small apps on the side for me. SBSettings, Status Notifier, Custom Carrier logo, PdaNet (why I jailbroke considering Optus Australia want to charge $10 per month for tethering) and a few other standalone apps.
I use Soda with 5 columns and 5 rows. The image below is a few weeks old so it's changed a bit since then, you get the idea though! And here's my lockscreen: I haven't had much of a chance to play with this yet so I should be able to tidy it up a little!!
I use Illuminous and Transparent Dock with the 5 Icon Dock, plus I use the Infected Mushroom sound pack and have a purple battery mod.
I have an awesome Daft punk theme that has the interstella 5555 poster (minus writing) as the background: And when I press the sleep button on top it says "Harder" And when I press it to use it again it says "better" and when I plug in the usb cable or charger it says "faster" No idea how you get it to say stronger yet
